Old 07-17-2007
saurav16's Avatar
saurav16 is on a distinguished road
Send a message via AIM to saurav16
how to use marine tex
I had a quick question. I am repairing a really small area .25 inch by 3inches. The instructions say to mix the entire vile of hardner to the putty. Is there another way to do it so I don't waste the entire package? Is it really ok to do this while the boat is in the water as water may hit the site being repaired? The water temp is 75F deg. Although with water touching it it may be hard to prepare the surface (sanding/scraping) and cleaning with thinner? Anyone done any repair like that? Thanks!
Old 07-17-2007
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
Marine-tex mixes by ratio, so determine the ratio of hardner to putty, and do it in that amount. It works much like marine bondo. Can't really say if it will be bothered if it gets wet.
Currently enroute, Belhaven to Oriental
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 07-17-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
I have never worked with MarineTex on a wet surface, but believe the added liquid would have a detrimental affect. If the repair area is close to the waterline, consider shifting some onboard ballast to raise that section off the water a bit. Mix it to a ratio of catalyst-1 : 5-putty.
True Blue . . .
sold the Nauticat
Old 07-17-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
Just be sure the gouge is nice and clean. If you are using a small kit (marinetex also comes in quarts, etc) I find other things that need repair and just use the whole thing. If it might get splashed/wet, just cover the repair with plastic wrap (saran rap) until in cures. Be very careful! That is some dang hard stuff, you don't want to have to sand it. It is also possible to run your squeegee(sp?) over the pastic wrap for a smoother finish. Just be sure that there is no extra that will have to be sanded. If so, it could damage the surrounding gelcoat when doing so.
Old 07-17-2007
camaraderie's Avatar
moderate?
From the marine tex site:
Can I apply Marine-Tex under the water?
Yes, but the Marine-Tex is likely to wash away in moving water while it is trying to cure. The FlexSet is better for underwater applications because it is of a denser consistency. If you would like to try an underwater application, mix the epoxy above the water, then deposit it on wax paper or plastic wrap. Slide the wax paper or plastic wrap onto the palm of your hand with epoxy facing up. Take it below the water line and apply to surface. Be careful not to smack or pancake the product onto the surface, this will trap water under the epoxy. Instead, roll the epoxy onto the repair to push water out of the way. Leave wax paper/plastic wrap on the repair while full cure takes place for best results.
Old 07-17-2007
Gary M's Avatar
Gary M is on a distinguished road
The gouge will have to be clean and dry when you apply the Marinetex, don't think a small amount of moisture on the outside will hurt after it is on.
You will find the base it quite stiff and hard to work but the catalyst softens it up. The mix ratio is not critical, I just guess at the right amount and it has always set up properly. I put both parts on a small piece of plywood or similar and then mix it well with a putty knife. As USC has already said get it smoothed out very close to your final finish before it sets up as it is VERY hard to sand when set up.
Gary
Old 07-17-2007
I'd emphasize that you want to get the MarineTex as close to the final faired shape as possible, since it is rather difficult to fair.
Old 07-17-2007
TrueBlue's Avatar
Señor Member
I've had good success fairing the surface after setting, by shaving the patch with a single-edge razor blade. Wet sand, apply rubbing compound, Finesse-It II, then wax.
True Blue . . .
sold the Nauticat
Low-cost outfitting GoodOldBoat Gear and Maintenance Articles 4 11-09-2011 12:05 AM
Marine Surplus and Consignment Shopping Sue & Larry Cruising Articles 0 10-14-1999 08:00 PM
Marine Radios Overview Jim Sexton Seamanship Articles 0 09-30-1999 08:00 PM
Marine Radios Overview Jim Sexton Gear and Maintenance Articles 0 09-30-1999 08:00 PM
Marine Radios Overview Jim Sexton Her Sailnet Articles 0 09-30-1999 08:00 PM
