Old 07-17-2007
Northeaster is on a distinguished road
Raw water strainer size??
How big of a Perko or Groco strainer should I use with a Yanmar 2GM?
Have a cheap plastic one now, that may be leaking air.
I will check the water pump hose size tonight, but it's approx 1/2" - 3/4'.
Does the strainer model 3/4" or 1 1/2" mean the basket size, or the fitting / hose size?
Thanks!!
Old 07-17-2007
Cruisingdad's Avatar
Best Looking Moderator
The inches you are referring to is the fitting - hose size. THe strainers are measured in ml as I recall.
Thus, a graco 3/4 npt 755 would be a 3/4 inch fitting 750 ml strainer.
As far as the size, I have always been of the opiniOn that the bigger the better. Still, I bet 750 ml would "work" for you, with larger being better. Check with Yanmar on that and do not quote me on the size. But get rid of that crappy plastic one!! THe bronze ones are sooo much easier to clean and a much better product in my opinion.
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 07-17-2007
CD - Thanks for the info!
Old 07-17-2007
RichH's Avatar
RichH will become famous soon enough
Simply match the hose (ID) size on the engine to the inlet/outlet size of the strainer ..... and all will be 'optimized'.
Connecting raw water cooling to water heater Northeaster Gear & Maintenance 18 04-28-2007 06:11 PM
Raw water cooling reluctance Boat Review and Purchase Forum 1 03-16-2007 04:28 PM
leak from engine raw water siphon break i670684 Gear & Maintenance 2 08-11-2003 05:53 AM
Sea Water Strainer joub Gear & Maintenance 2 01-19-2003 07:05 AM
Raw Water in Engine wmwtlw Gear & Maintenance 3 02-25-2001 11:31 AM
