07-26-2007
This is why I figure you pay more for the SolarStik to solve a small boat problem of not enough deck space/no arch than for its benefits. It's a compromise, like everything else. If you have enough room for two or three 130 W panels (about $1,500), plus a wind genset ($1,000-$1,500), it's cheaper to put 'em up facing the zenith and forget about them and you will likely get the same amps or better than two 50 W panels exquisitely and optimally aimed off a pole bolted into the transom of a 30 footer...and which will cost the same as the "passive" panel set up.
Of course, in the first scenario, you continue to make power on breezy nights and cloudy days.
This is a rare case where having a bigger boat actually saves you money, because the "real estate" is cheaper.
