Charging Regulators - SailNet Community
Blogs
Old 03-06-2002
davealves is on a distinguished road
Charging Regulators
I have recently replaced a very old 110V battery charger with a new electronic charger. I have been amazed by the difference in the deep cycle battery charging. I''m at a dock for the winter, but will be on a mooring all summer. My question is: Will I see the same difference in battery charge if I replace my old regulator with one of the new electronic regulators? Thank you all in advance for your input.
Dave Alves
S/V Fluke
Old 03-08-2002
JEFryar is on a distinguished road
Charging Regulators
Dave.
Some of the newer electronic charging systems monitor the batteries and adjust the charge they are receiving. You might look into installing a battery combiner/monitor. This will give you a similar operation in that the batteries are monitored and the charge taylored to the recharge needed for that battery. I think Westmarine sells one.
JEF
Old 03-19-2002
fer@fer's Avatar
fer@fer is on a distinguished road
Charging Regulators
Indeed it will.
Step regulators can match almost 100 % charge on your banks. As said, if you also control with a Link 10 monitor, you will be surprised of the improving.
Old 03-31-2002
Constantin is on a distinguished road
Charging Regulators
Modern regulators are amazing creatures. Not only do they incorporate 3-step charging for the fastest charge possible, they also monitor the battery temperature to prevent thermal runaway. One of Balmars even monitors the temperature of your alternator to not overheat it.
However, the first step should be to ensure that your electrical system can handle the charge currents of a modern charging system. Are the wires big enough. Are the terminals clean, greased, and covered. Does your battery box have adequate ventilation? Also, you may want to consider installing a monitoring system first to see the before and after. We went for a Heart Link 20 so that we could separately monitor the two battery banks (starter, house) and see at a glance what their charge status is (nifty LED bar system with several colors).
I have been extremely happy with my Ample Power charging system consisting of a altternator on the Perkins diesel and a NextStep regulator. Finally it was no longer an exception to have full batteries. At idle, the house bank typically bulk charges at 50A, otherwise at 100A! Now that I have installed AGM batteries, having a powerful charging system is even better.
If you''re interested, have a look at <a href=http://www.vonwentzel.net/Prout/02.Electrical/04.Charge/index.html>that section of my web-site</a> where I show the installation. Lastly, Ample Power has a great website as well and professional customer service. Not only do you get to talk to humans, but they actually know the product, offer excellent advice, and when something breaks, they stand behind their reputation and send a replacement right away.
Charging adapter for phones, laptops,etc Douggie Gear & Maintenance 10 12-03-2004 05:49 PM
Combining 110v & 12v charging systems mmccoy Gear & Maintenance 5 08-25-2004 01:41 AM
Battery Charging Question gwp Gear & Maintenance 6 05-08-2004 12:28 AM
Baterry Charging System Horizonlight Gear & Maintenance 4 07-14-2001 03:35 AM
Batteries & Charging capedory30 General Discussion (sailing related) 2 04-27-2001 05:05 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
