Old 07-17-2007
bestfriend's Avatar
Hitchin' a ride
bestfriend is a jewel in the rough bestfriend is a jewel in the rough bestfriend is a jewel in the rough
How do I fix my sink?
This is about a 3/16 inch hole in the bottom corner of the sink. How do I fix it? Whats the quick and easy way, and what is the longer, correct way? Thanks.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
Old 07-17-2007
BF-
is it a hole or just a ding in the sink's gelcoat?
If it is a hole, tape over the bottom of the hole and fill it with thickened epoxy...then gelcoat over it.
Old 07-17-2007
bestfriend's Avatar
Hitchin' a ride
The gelcoat is punched through, but I forgot to look and see if it goes all the way through. I wasn't sure what it was made of, thanks SD.
Vaya con Dios
Old 07-17-2007
If it is gelcoat, then it is probably a fiberglass sink. In any case, as long as it isn't some of the slicker plastics...the thickened epoxy should seal a hold that size fairly well.
If the hole doesn't go through and it is just a shallow divot in the gelcoat... grind the divot a bit, wipe with acetone and then just gelcoat it. Deeper divots need to be filled, even if they don't go through.
Old 07-18-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
bestfriend,
That sure dosen't look like gelcoat to my eyes.
My galley sink is stainless, but the head sinks are both of a porcelain enameled finish over metal. The best way to repair a porcelain chip is with a repair compound made exclusively for this. There are several out there - here's one I found after a quick search:
Porcelain chip repair
True Blue . . .
sold the Nauticat
Old 07-18-2007
If it is porcelain and the underlying sink is stainless, and you've managed to punch a hole in the steel...I'd still be for filling it with thickened epoxy and then coating it.
TB-
How can you tell.... the photo is badly exposed and a bit out of focus...
Old 07-18-2007
TrueBlue's Avatar
Señor Member
Yeah - I know it's out of focus, but porcelain chips circumferent around an impact and the blackened base material looks like cast iron - a popular metal for porcelain enameled plumbing fixtures.
I broke up my old cast iron bath tub with a sledge hammer last year to replace with a whirlpool tub . . . that was one heavy tub, and this was the easiest way to get it out of the house. After laboring over that nasty job for an hour - I learned the physical properties of chipped porcelain over cast iron -
True Blue . . .
sold the Nauticat
Old 07-18-2007
LOL...that's one way to learn about it... But cast iron is a wierd choice of materials for a boat sink... They're usually fiberglass or stainless steel.
Old 07-18-2007
TrueBlue's Avatar
Señor Member
Could very well be gelcoat over a dark glass mat material - most likely is. Most firemen I know are part-time tradesmen, so this should be easy enough for BF to find out.
True Blue . . .
sold the Nauticat
Old 07-18-2007
bestfriend's Avatar
Hitchin' a ride
I'll be down there tomorrow, place your bets....
Vaya con Dios
Siphon through Sink? NbyNW Learning to Sail 1 06-01-2005 07:57 AM
Lines of Position, Bearings, and Fixes Jim Sexton Seamanship Articles 0 03-23-2004 07:00 PM
Lines of Position, Bearings, and Fixes Jim Sexton Her Sailnet Articles 0 03-23-2004 07:00 PM
Leaking Seacocks and Sink Drains Tom Wood Buying a Boat Articles 0 09-11-2002 08:00 PM
Leaking Seacocks and Sink Drains Tom Wood Gear and Maintenance Articles 0 09-11-2002 08:00 PM
