Old 07-18-2007
MarkinPA is on a distinguished road
Deck / Cockpit Oxidation question.
Just purchased a 1994 Catalina 270, and there is slight oxidation (comes off on hand when wiped) on the upper portion of the boat (deck and cockpit). Is there a product that can be used? I see on some other threads that people recommend 3m Marine Fiberglass Restorer and Wax.
Due to the slight oxidation, is this product necessary? Or will a good washing and wax take care of this problem? Also, what is the best thing to use on the non-skid area?
Thanks in advance,
~Mark
Old 07-18-2007
I'd try the 3M Fiberglass Restorer and Wax, as it is a pretty good product. Woody Wax is what I would recommend for the non-skid.
Old 07-18-2007
Owner, Green Bay Packers
sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice sailaway21 is just really nice
If that does not do it, you might try some polishing compound or even rubbing compound. Your goal is to remove the oxidation that has already occurred and then wax it to protect it from future degradation. What's causing it to oxidized? UV light mostly.
Wm. F. Buckley, Jr.
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
The Cruising Cockpit Sue & Larry Buying a Boat Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Gear and Maintenance Articles 0 07-08-2003 08:00 PM
The Cruising Cockpit Sue & Larry Her Sailnet Articles 0 07-08-2003 08:00 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 08:00 PM
