Propane Sensor going off... - SailNet Community
post #1 of 16 Old 07-19-2007 Thread Starter
Here .. Pull this
I put in a new propane control system - Trident - with solenoid, alarm/switch panel and two sensors. One sensor is in the cockpit locker and the other is in the cabin. When I turn the system switch on, the cabin sensor sets off the alarm.
This should indicate the presence of propane, but after doing a lot of checking and testing - there are no leaks anywhere. I am wondering if there are other gases that set these things off ??? Battery gas perhaps ???
Wiring is fine, as the alarm turns off after I blow some air over the sensor and stays off until the boat is closed up.
Ideas ??
Sailormann is offline
post #2 of 16 Old 07-19-2007
This is the normal test sequence. When you first switch on,
the horn and warning light come on for about fifteen seconds to show you that it is operational, and then it goes of. At this point you push the button to turn the warning light off.
alanporter is offline
post #3 of 16 Old 07-19-2007
Depending on the actual sensor design/type, it's possible that any combustible vapour may set it off...
Can you swap the sensors around and see if the problem moves with it? If so then the detector itself may be faulty.
If the alarm goes off in the cabin again, it's possible something is actually there. Do you have any solvents or other volatile materials stored on board?
Faster is offline
post #4 of 16 Old 07-19-2007
I would turn off the propane at the tanks. Then air out the boat and see if it still goes off. Could be a defective detector. Could be a tiny leak.
Be very careful.
A couple of years ago in a neighboring county a house was completely destroyed by a propane leak. Nothing left but a debris field and a hole where the basement used to be. An elderly lady called a repair man saying she smelled propane. He came out and "fixed the problem". She called again the next day and said she still smelled propane. He came back out, went down in the basement, cell phone rang. No more repair man, elderly lady or house.
rewell6 is offline
post #5 of 16 Old 07-19-2007 Thread Starter
Here .. Pull this
Stays on - doesn't go off until I aerate the sensor.
Good idea - I'll try this on the weekend. Thanks !
Cleaning products, but I don't think that they would do it... Will have to look carefully I guess.
Happens when the tank fitting is closed and solenoid is closed. Have checked everything for leaks pretty carefully as I was on the fence re propane vs alcohol.
post #6 of 16 Old 07-19-2007
Stop eating beans...
Actually, have you pressure tested the propane lines on your boat?? Since you tried shutting off the valve on the propane tank to see if that changes anything... it could be a different gas, a faulty sensor or some other gremlin. Also, where is the sensor located?? Propane sensors should be mounted fairly low, not high, since propane is heavier than air. If you've mounted it high, then it is more likely that some other gas is setting it off, if the sensor isn't flaky.
sailingdog is offline
post #7 of 16 Old 07-19-2007
Check for leak by:
1. Turn on propane at tank
2. Turn on solenoid
3. Turn off propane valve at tank.
4. Note pressure gauge.
5. Wait 5 minutes and note if pressure has changed.
That's the reason those gauges are there. Now that you're sure you don't have a serious leak, start eliminating the alarm issue.
stevemac00 is offline
post #8 of 16 Old 07-19-2007
Check for leak by:
1. Turn on propane at tank (make sure stove is off)
2. Turn on solenoid
post #9 of 16 Old 07-19-2007
Valiente's Avatar
Do you have a gas engine? My sensor detects propane and gasoline (although I took it out of the old Atomic 4 boat and into the new diesel boat) and it went off every time I cleaned out the fuel sediment bowl (I never installed propane on the old boat).
Valiente is offline
post #10 of 16 Old 07-19-2007
"Sparkie"
j34035's Avatar
easy item: Check the cables to make sure they are not damaged. A broken cable can cause the alarm to go off.
DD
j34035 is offline
Propane Cabin Heater Mysun Gear & Maintenance 9 06-08-2009 12:29 AM
Wondering about where to put propane sensors... Sailormann Gear & Maintenance 5 05-15-2007 12:58 AM
Refilling Propane Tanks Doreen Gounard Gear and Maintenance Articles 0 09-01-2003 09:00 PM
From Propane to Butane John Kretschmer Gear and Maintenance Articles 0 09-23-1999 09:00 PM
From Propane to Butane John Kretschmer Cruising Articles 0 09-23-1999 09:00 PM
