07-19-2007
The wider beam and flush decks of racing boats tend to keep they in an inverted position. With the advent of the new canting keels, most races have required the boats be able to self-right by canting the keel and starting the self-righting process by doing so.
LWinters– The majority of ships on the ocean do not self-right... It could be argued that a catamaran or a trimaran has a position of ultimate stability—upside down with the mast acting as a keel. It could also be argued that a monohull keel boat has a position of ultimate stability of sitting upright on the bottom of the ocean...  Not being as likely to sink is a huge advantage of a multihull when doing offshore work.
