Old 07-19-2007
dave6330 is on a distinguished road
Spot Painting Bottom Paint
I've had my boat out of the water for a year now and have just returned to the States. I'm anxious to get her back into the water and do some sailing but I noticed some chipped areas on the botom paint. My question is whether or not I can "spot paint" the chipped areas (after sanding) and forgo a complete botom paint job 'til next year? I'm chompin' at the bit to get back but I don't want to mess anything up either.
Old 07-19-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
Some paints would require a new coat after being out of the water that long.
If not that kind, then it would be ok. You'll need to research your paint.
Old 07-19-2007
SanderO is an unknown quantity at this point
This Spring I used the cheapest West ablative paint and did only one coat. Works great! How much money have I wasted on bottom paints. Oy!
jef
sv shiva
Old 07-19-2007
Dave-
Most hard epoxy bottom paints would require re-painting, while most ablatives would survive being out of the water that long. If it is an ablative, you might want to check with the manufacturer to see if you can apply it directly over an old layer of itself... if so...then you can probably just spot-paint the bottom.
Old 07-20-2007
Thanks all - the current bottom paint is an ablative but I don't know the specific brand (I had the bottom painted just after we bought the boat four years back). I'll give her a go with spot painting this year and pull it next year for a full bottom paint (when I'm not so pressed for time).
Confessions of a bottom feeder PracticalSailor Gear and Maintenance Articles 9 06-18-2008 04:33 PM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Bottom Paint Compatibility Dan Dickison Gear and Maintenance Articles 0 01-24-2001 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
