  #11 (permalink)
Old 03-31-2002
Pangaea is on a distinguished road
Cabin sole finish
I am building a solid teak and holly sole in my boat and want a thick finnish. I have seen this type of finnish on tables that is poured on and dries very thick and clear. Does anybody know anything about this?
Dennis L.
  #12 (permalink)
Old 03-31-2002
sailor
ndsailor is on a distinguished road
Send a message via Yahoo to ndsailor
Cabin sole finish
Hi Dennis, the stuff you want is called kleer kote. Its mostly used on bar room tables and such. I just used it to refinish my tabletop after putting a chart and ship wreck coins on its surface. Its a 2 part epoxy, works and looks great. (shopmaninc.com/kk121.html)...........Rick
  #13 (permalink)
Old 03-31-2002
sailor
Cabin sole finish
P.S. its very important to use a hair dryer or heat gun across the surface of the kleer kote after it has been brushed out across the surface to burst small bubbles...remember that....I believe the web site has instructions on application to that effect too......Rick
  #14 (permalink)
Old 03-31-2002
Cabin sole finish
Hi Rick,
Thanks alot! Yeah, thats the stuff. I''ll get back to you and let you know how it turned out but it won''t be completly done for a while because I am a long distance truck driver now. (and thanks for the important tip).
Now.... I''m not a painter so let me ask since you''ve used it. Do you think this product is suitable for this use?
thanx
Dennis L.
  #15 (permalink)
Old 03-31-2002
sailor
Cabin sole finish
an undeniable...YES....even when it eventually gets scuffed up,(which takes alot) scrub it clean - paint on a fresh coat - and it levels out and looks like new again.....Rick
  #16 (permalink)
Old 03-31-2002
sailor
Cabin sole finish
P.S. you can be an awful painter and still come out with great results with this stuff.. its thick but as you glop it on and spread it out and heat it alittle with a heat gun, it just thins and levels out beautifully. Just keep everything clean before applying....Rick
Advice refinishing teak and holly sole mcagney Gear & Maintenance 11 09-24-2009 07:03 AM
ISLANDER 29 CABIN SOLE mauricefrompolo Gear & Maintenance 2 03-02-2009 10:57 PM
Cabin Step Mast JNBDeVore Gear & Maintenance 6 10-03-2007 12:35 PM
Bruce about to finish waltward General Discussion (sailing related) 0 02-22-2005 07:27 PM
vinyl cabin sole creek Gear & Maintenance 0 03-20-2001 05:47 AM
