Coolant Question - Page 2 - SailNet Community
post #11 of 19 Old 07-20-2007
Best Looking MALE Mod
Cruisingdad's Avatar
Labatt,
Call Boatswain in California. Their number is: (949) 642-6800. THey are a Yanmar distributor. VERY NICE and helpful. I have dealt with them on many Catalina related issues. Ask for Eddy. He knows his stuff.
Get the straight and right answers directly from them. If you call them right now you should be able to reach them.
- CD
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #12 of 19 Old 07-20-2007 Thread Starter
I'd rather be sailing
labatt's Avatar
CD - Thanks for the reference... just tried them and Eddie isn't around until Thursday and nobody else was available at the moment... I'll keep doing my Internet searches
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
labatt is offline
post #13 of 19 Old 07-20-2007
Call the Florida (Mastry Engines)... look them up under yanmar.com. They are the East COast Distributor for Yanmar-Catalina. I have dealt with them too. I forget the guys name there... I think it is Bob??? But anyways, very helpful there too. You will not speak to them until Monday, obviously, but a lot better than Thursday.
- CD
Sailnet Moderator
My Website:
Follow My Blog at:
post #14 of 19 Old 07-20-2007
Courtney the Dancer
jrd22's Avatar
Any heavy duty truck or bus type of coolant is OK, Fleetguard is one brand I can think of. Should be able to get it at any auto parts store. Pre-mixed is easiest. We run it in all our diesel trucks and equipment, as well as our Yanmar and Volvo boat engines. It should say that it is recommended for heavy duty diesel engines on the jug. No need to buy Yanmar, Volvo, etc brand coolant.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #15 of 19 Old 07-20-2007
Hitchin' a ride
bestfriend's Avatar
Hmmm. I always thought, what the hell, antifreeze is antifreeze. On the short term, thats probably right. Its made up mostly of ethyl glycol, with about 5 percent additives. Its that 5 percent that makes the difference as far as what kind of anti-corrosive properties the coolant will have. Different types break down at different rates and will protect against different corrosive factors. I bought a new Ford in '03 and took it to one of those speedy lube places one time. They told me that it needed new coolant and that the system was rusted and needed service. They didn't realize that Ford had switched to a different coolant that is orange, not green. Diesel coolants tend to be a different viscosity, and can have seals made from different materials and different parts altogether. While you may not be doing short term damage, in the long term, you probably are if you are using auto coolant. I would recommend using what the manufacturer says to use, or at least a high grade diesel automotive one.
Oh yeah, and use distilled water.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
bestfriend is offline
post #16 of 19 Old 07-20-2007
T37Chef's Avatar
Originally Posted by Valiente View Post
I use green "diesel coolant" at 100% strength.
I'm not a trained mechanic either, but it has always been my understanding you should go 50/50, are you going 100% because its "diesel" coolant?
I thought (maybe still do) I had a "running hot" issue, changed the coolant, the thermo, cleaned out the heat exchanger, changed hoses, etc. The gage still says 210. So I shot a infrared thermometer all over the motor, it didn't read anything over 170, even at the injectors...I felt much better and now think it is the just a faulty sender or gage???
Shawn
T37Chef is online now
post #17 of 19 Old 07-20-2007
T37Chef-
The sender or gauge could be mis-calibrated.
IIRC, most anti-freeze/coolant solutions have better heat absorbtion capacity and higher boiling, lower freezing points when mixed 50/50.
sailingdog is offline
post #18 of 19 Old 07-20-2007
BarryL's Avatar
Repair Manual
Hello,
You really should get a copy of the service manual. It will have answers to all your questions.
I have the manual for the Universal M25 engine. For coolant it states 'use antifreeze.' Any automotive type coolant will be fine.
If you don't know when the coolant was last changed, you might as well drain it and change it now. There should be a drain on the engine block. Let all the coolant out (please catch it in a pan for proper disposal). Then fill with 50 / 50 coolant and water (unless you buy the stuff that is pre-mixed. There will be a coolant bleed screw somewhere on the engine, you need to find it.
Lastly, do you have an engine heated hot water heater? If so, bleeding all the air out can be a little complicated so make sure you do a thorough job. You will have to check the overflow tank a few times to make sure you have enough coolant added.
Good luck,
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #19 of 19 Old 07-21-2007
Valiente's Avatar
I went 100% because it's the same coolant I put in there last fall, just before I winterized the engine raw water circuit, A/C and head with pink "plumber's" antifreeze. My boat was out on a peninsula in a cradle exposed directly to winter winds...basically, I didn't want to screw around with 50/50 mixes if the temperature got to -25C, which it didn't (although an 80 knot gust blew over five boats where I was).
If there's a case to be made for going 50/50 in a cooling circuit, I'd like to hear it. It's not like a jug of coolant is particularly expensive.
Valiente is offline
Ladder question mcain Gear & Maintenance 14 08-03-2007 11:28 PM
Odd coolant leak issue Valiente Gear & Maintenance 12 05-08-2007 01:14 PM
Shore power question Omatako Gear & Maintenance 23 04-13-2007 11:33 PM
Quick displacement question... kclaybrook General Discussion (sailing related) 19 07-13-2006 09:30 PM
Cruising home/base/marina ICW question thorJ30 General Discussion (sailing related) 3 05-30-2005 06:53 PM
