07-20-2007
SaltyPat-
Most marine stoves that use a gas (CNG, Butane, Propane) as the fuel have a thermocouple or sensor that senses the burner operation and kills the the gas when no flame is detected. You generally need to hold the match in the lighting position for a few seconds to allow the flames to heat the sensor and not kill the gas feed as soon as you remove the match.
