Old 07-20-2007
cbayermd is on a distinguished road
teak caulking question
the caulking between the boards in my cockpit has started to melt in some areas. it is a gooey sticky mess and does not seem to want to re-harden at all. two questions:
1) what in the world is causing this to happen?
2) do i need to remove and re-caulk the entire area?
Old 07-20-2007
did you spill anything on the teak in the affected area??
Old 07-21-2007
onokaya is on a distinguished road
By asking the question the obvious answer is yes. Get a Dremel(preferably with a router attachment guide) and grind the caulk out of the seams. Tape them off and use a spatula and a polysulfide(I like SIS 440 Teak Deck Caulking) to fill the seams.
Old 07-23-2007
i don't think i spilled anything, although this is an area right next to the fuel intake so maybe a little diesel got on it.
i figured i would just have to re-caulk as you point out and will get on that today. just hope it doesn't start happening all over the decks.
thanks so much for your help!
Old 07-23-2007
RichH's Avatar
RichH will become famous soon enough
Probably a chemical reaction with either spilled diesel fuel or a reaction to any sealing compound or coating you used. "reef" out (old file with the 'tang' bent into a 'hook') the old caulk down to bare dry wood then recaulk or use a laminate trimmer (with guide) to clean out the seam to bare wood. Most caulked seams need a 'bond breaker' in the bottom of the seam before laying in new caulk so the bottom of the seam is 'free-floating' and doesnt adhere to the 'bottom' of the seam. I use 1/4" 3M 'fine line' masking tape as the bond breaker.
Best caulk Ive found recently is oxime cure single part teak decking caulk from TDS ... pretty impervious to just about everything used or spilled on a boat. This is whats used to caulk the deck on most modern mega-yachts. Doenst shrink when curing.
http://www.jamestowndistributors.com...ystems+-+Caulk
Old 07-23-2007
TrueBlue's Avatar
Seńor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
I bought a case of SIS 440 (TDS) last year with the intent to recaulk after reefing out much of my deck's caulking. The original caulk is actually in good condition - hasn't turned gummy or sticky.
The problem started with the PO, when he decided to apply a wood stain to the teak with the intent to keep that "new blonde" look, instead of the natural grey color. Eventually, the stain broke the polysulphide caulking bond with the sides of each planking groove and began pulling out in some areas - like rubber bands.
The good news is, the caulk comes out fairly easily and it's not a difficult job - have done some sections . . . just procrastinating finishing because it's a very time-consuming project. Lot's of teak decking on my boat.
True Blue . . .
sold the Nauticat
Old 07-23-2007
It does sound like the diesel exposure may be the cause of the caulk deteriorating. It might be a good idea to chec the next caulk you use for the repair for resistance to diesel fuel.
Old 04-14-2008
sailortjk1's Avatar
Found this old thread trough a search.
I have a small teak inlay on the swim step that I am replacing, its about 1.5' x 1'. We noticed that water had gotten under it last year and of course over the winter.
Is the choice of the board for caulk still the TDS SIS440?
Can this be used to caulk around the Gelcoat as well?
What do I use to glue the inlay down? Would 3M 4200 work for this?
It is a small inlay of teak on my swim step, it is not a teak deck boat.
The inlay is not secured with fastners, just adhesive.
Courtney is My Hero
Teak question PBzeer Gear & Maintenance 20 03-16-2007 09:08 PM
Teak Deck Caulking Leaks dsbentley Gear & Maintenance 3 03-13-2007 07:49 PM
Techniques for Removing Teak Decks Sue & Larry Buying a Boat Articles 0 11-24-2003 07:00 PM
Homemade Teak Decks SailNet Gear and Maintenance Articles 0 08-01-2002 08:00 PM
Bristol Teak Tom Wood Gear and Maintenance Articles 0 11-02-1999 07:00 PM
