07-21-2007
Zaldog-
Is there any reason you need to have the boom be adjustable in height? If the answer is no, then I would recommend you do something similar to what PDXgrebe has suggested or done.
I am also a bit curious as to how your cunningham is rigged, that the gooseneck moving would prevent you from being able to use it. I can see how it might be affected if the boom was sliding too far up the mast, but not if it was dropping. Or is it just that the movement of the boom is preventing it from tensioning/flattening the sail. In either case, affixing the boom gooseneck to the mast, per PDX's suggestions would fix the problem.
