Old 07-21-2007
slocum2 is on a distinguished road
OH NO, Where did all that water come from?
I finnally put the boat in the water this past week with minor problems. A drip, drip from the stern tube and an impeller that wouldn't pump. I changed the impeller and while I was at it a hose that had seen better days. Everytrhing was tight and the boat sat happy for two days with only the drip, drip from the stern tube.
Yesterday I was taking down to the mooring, a 25 mile trip and all was well, I checked the bilges every few minutes and was about to start relaxing when I looked again and we had water to the floorboards. We had been running on the engine for 30 minutes before this. The boat is a 33 foot Offshore, with a Universal 16.
I stopped the engine, shut the seacock to the engine (all others were closed) passed up the lifejackets and begun to pump. Using two bilge pumps and a hand pump it was cleared in a few minutes.
Here is the mystery:
1- Nothing appears to be leaking in the engine. All hoses are tight, the heat exchanger is not leaking, my new impeller is pumping.
2- All other seacocks are closed and dry
3- I can't find a leak!
We motored back (after my heart settled down) with no problem and no leak.
Where did the water come from???
Old 07-21-2007
I'd rather be sailing
labatt will become famous soon enough
Did you check your fresh water tanks or hot water heater to see if any hoses broke and you happened to have water in them?
s/v "Pelican" Passport 40 #076- Finished Cruising - for the moment -
"Don't dream your life, live your dream" - Bob Bitchin'
"I'll see it when I believe it" - Me
Old 07-21-2007
Tartan34C will become famous soon enough
Is the exhaust system OK? If that’s leaking you pump water into the boat while the engine is running. You might also get exhaust fumes inside the boat so be careful about this. Some systems use a water jacket with the water being injected into the exhaust near the hull and others use a mixing elbow to inject water into the exhaust at the manifold.
All the best,
Robert Gainer
Old 07-21-2007
chuckg5's Avatar
chuckg5 is on a distinguished road
first thing is to stick your finger in the water an taste it.
fresh or salty?
Old 07-21-2007
Quit calling me a member
morganmike is on a distinguished road
Check the bottom of your raw water pump with your finger. You likely have a bad seal, and water is running either out the seal ports or from the gasket seat. I had this problem the first time I rebuilt my pump, and it can be very hard to spot visually if the stream is on the underside of the pump, running along an underside edge of the crankcase, and down a mount to the bilge. It filled my bilge to the floorboards in 30 - 60 minutes of engine operation.
Old 07-21-2007
the mysterycontinues
Thanks for all your input. I ran the boat for a half hour today and no water to be seen. I don't think it came from heater or watertank as they seem tight.
The mystery continues
Old 07-21-2007
werebeagle's Avatar
Alex, not full of crap
werebeagle will become famous soon enough werebeagle will become famous soon enough
have any Frenchmen been seen in the area?
Charlie
Courtney's my Dancing Angel
Where am I, and where's my paddle?
It's not impossible, it just costs more.
Give me ambiguity, or give me something else.
Old 07-22-2007
bestfriend's Avatar
Hitchin' a ride
bestfriend is a jewel in the rough bestfriend is a jewel in the rough bestfriend is a jewel in the rough
Good one Charlie.
I had a similar problem, and it was hard to find because it was the water heater relief valve. It only happened when both the water pump and the water heater were on at the same time. It nearly emptied one of my tanks.
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
Old 07-22-2007
SanderO is an unknown quantity at this point
Your water tanks leaked?
jef
sv shiva
Water, Water Everywhere Tania Aebi Cruising Articles 0 06-14-2004 08:00 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
