Sail repair - Tape or Sew? w/ pictures - Page 2 - SailNet Community
post #11 of 20 Old 07-28-2007
Often tape doesn't seem to hold on sails. I know part of that is because there's usually some microfine salt spray that acts as a release powder. But something I found out (don't ask me how or why) is that if you use a good glue/epoxy and then place a good tape over it, the tape gets permanently bound to the glue.
On a sail, I'd vote for urethane glue, like Goop, applied after washing the area clean (water then alcohol), topped with sail tape or gaffers tape (which is similar to duct tape, but 3x more expensive with an adhesive that doesn't turn to goo). Plumbers Goop is supposed to have things in it making it bond better to plastics, so I'd try either that one or plain Goop.
And then of course if you can--still stitch over the repair.
hellosailor is offline
post #12 of 20 Old 07-28-2007
Even if you have to hand sew it, it doesn't take much time. I find hand sewing sail material easier than hand sewing cloth because everything is bigger, the needles, threading, stitches, everything.
wind_magic is offline
post #13 of 20 Old 07-28-2007
Try a iron.As in clothing.Put a double layer of cotton{t-shirt} above and below.Heat will make tape stick better.
Mark
travler37 is offline
post #14 of 20 Old 07-29-2007
Heat in general is not good for laminated sails... I would advise against using an iron on laminated sails.
sailingdog is offline
post #15 of 20 Old 08-01-2007
Not HOT heat.Just around 70/80 degrees.No hotter than a summer day.Difference is sail is flat and supported when heated so glue works into sail.
Mark
post #16 of 20 Old 08-01-2007 Thread Starter
US25's Avatar
I wasn't going to post this picture because I was a little embarrased by my poor sewing skills, but I used the sail last night in a race (15 knot winds) and it held! I didn't use any heat, just tape on both sides and a little "professional" sewing.
[IMG]Photo Sharing and Video Hosting at Photobucket[/IMG]
US25 is offline
post #17 of 20 Old 08-01-2007
Freesail99's Avatar
Nice job want to do my boat cushions ......
S/V Scheherazade
Freesail99 is offline
post #18 of 20 Old 08-01-2007
The sewing really makes a huge difference, since the stitches help prevent the tape adhesive from being stressed in shear, rather than tension. Many adhesives will creep under shearing forces, but will be much stronger in tension.
post #19 of 20 Old 08-01-2007
I agree, I don't know why someone would want to avoid sewing a sail. Sailors go to more trouble to avoid sewing than it takes to sew it! I mean by the time you even drive to the store and buy tape and come back you could have already sewn the thing and be done with it.
post #20 of 20 Old 08-01-2007
The tape is nice because it holds itself in place while you're sewing, and keeps the rip or tear shut while you're sewing.
First Sail of the Season Bruce Caldwell Learning to Sail Articles 0 06-05-2003 09:00 PM
Sail Repair 101 Don Casey Seamanship Articles 0 03-10-2003 08:00 PM
Sail Repair 101 Don Casey Cruising Articles 0 03-10-2003 08:00 PM
Installing Roller Furling Sue & Larry Gear and Maintenance Articles 0 08-09-2002 09:00 PM
Racers' Sail Care Tips Dan Dickison Gear and Maintenance Articles 0 08-15-2001 09:00 PM
