07-24-2007
Sequitur-
It is called an Ankarolina.
Personally, I would not recommend it...since the breaking strength of the largest size is only 7000 lbs., which is pretty low for an anchor line. I use a 5/8" anchor rope, and it has a breaking strength of 12,200 lbs., and is much more chafe resistant than the nylon webbing used in the Ankarolina. Yet, the advertising copy for the Ankarolina states:
Ankarolina is a flat, polyester braid similar to a car seat belt. It is extremely durable and strong. Because it is so thin, you don't have to disconnect it from the anchor when not it use: just run it underneath the hatch cover.
With a breaking-strain of 5500 lbs., it has the same holding power as a 1" - 1.3" line. As you can see from the pictures, it requires much less space than the same amount of 1" rope!
BTW, if you want to stop a piece of webbing from howling under the force of the wind when it is under tension, you need to put about half-a-dozen twists in the webbing, and that will prevent it from making noise generally.
