Old 07-28-2007
jaschrumpf's Avatar
1975 Newport 28
jaschrumpf is on a distinguished road
POS connection for DC distribution panel
Sorry to address this point yet again, but I just want to be clear on this. From reading many of the posts about DC wiring, I've gathered that the POS wire to the DC distribution panel should run directly from the common terminal of the battery switch to the POS bus on the DC panel.
I ask for clarification because in my boat the POS lead comes from the same lead as the ammeter's connection to the POS terminal on the starter solenoid. The ammeter doesn't work, BTW, though the panel is getting its power.
Still, I thought that looked like the wrong place from which to feed the distribution panel, while the direct connection to the common battery switch connection sounds a lot more logical.
Thanks for any info!
Old 07-28-2007
PBzeer's Avatar
Wandering Aimlessly
PBzeer has a spectacular aura about PBzeer has a spectacular aura about PBzeer has a spectacular aura about
Though not an electrician, it is my understanding that your ammeter should be wired into your NEG side, through a shunt, then to the meter, not POS. The DC POS to your DC panel, should come from your common terminal on the battery selector switch. I would use at least 8ga wire for your POS lead to the panel.
On the hard at Deaton's Yacht Service, Oriental, NC
John
Ontario 32 - Aria
Free, is the heart, that lives not, in fear.
Full, is the spirit, that thinks not, of falling.
True, is the soul, that hesitates not, to give.
Alive, is the one, that believes, in love.
JCP
- Website & Blog
Old 07-28-2007
rewell6 is on a distinguished road
That's why your ammeter isn't working. The load is not passing through the meter.
Check out these two links.
http://www.6066gmcguy.org/ammeter.htm
http://www.caigauge.com/ammeterfit.htm
The POS terminal that feeds power to everything else is usually attached to the same terminal on the starter solenoid that the POS battery cable is attached to. I don't know why this is common. Older Chevy vehicles are like this as well.
Choosing and Installing Solar Panels Sue & Larry Gear and Maintenance Articles 0 11-06-2000 07:00 PM
