Bilgepump Backwash - Page 2 - SailNet Community
post #11 of 41 Old 07-30-2007
Obviously someone has hacked CD's account here, the real CD would never advocate putting a balky, problematic, flow restricting check valve in a high capacity bilge pump line.
T34C has the real answer, if you want a dry bilge you need a pump with a small diameter discharge that immediately goes up and through a loop or hump of some kind, so there will be minimum backwash when it shuts down. If you want high capacity bilge pumping, you need a pump with a huge discharge line--which will drop more water back in the bilge. By using two pumps, you also are relying on the "sipping" pump to deal with routine drips, leaving the larger pump with nearly no wear on it, until you need it. (And obviously separate float switches for the two, at different levels.) That also means you can wire up a bilge alarm on the same switch as the larger pump, knowing there's no reason it should ever go off unless you've got a major problem.
Go small and cheap on the "sipping" pump, and if it drains though something small and close that you always leave open, like the galley sink or the cockpit drain...no big deal. Less hose, less rise, less backwash.
That's what the other pump is there for anyway.
hellosailor is offline
post #12 of 41 Old 07-30-2007
THe problem, dear original poster, lies in your float switch.
You see, they are designed to set the pump on at a higher level, but only disarm the pump at a lower level.
Your switch lost the difference between level high and level low, sometimes only a few centimeters difference, and that happens as they age....like old men....anyway, just get a float switch from Westamarine for $20, and don't come back!!! only joking...I had that problem many times in the past, when floating technology was not to good.
Was that clear???
By the way, I am the easiest, least offendable, best looking, finest yacht person on this forum!
Giulietta is offline
post #13 of 41 Old 07-30-2007
"finest yacht person"
Oh dear, G's finally gotten someone so mad they neutered him. (Or would you prefer "it" now?)
< G >
post #14 of 41 Old 07-30-2007
Seņor Member
TrueBlue's Avatar
Giu, the finest yacht-unuch on sailnet.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #15 of 41 Old 07-30-2007
OK, here is a drawing of said switch.
HOWEVER, if your pump has a built in switch...time to get a new one...
I have these on my boat...SWITCH Make sure to check if Sailnet doesn't sell them before going anywhere.
And I have two of these with built in switches PUMP
TB is a loser....
post #16 of 41 Old 07-30-2007
TB....get a spell checker
post #17 of 41 Old 07-30-2007
Thanks Courtney.
Finally, someone with exceptionally good taste has realized the biggest truth that has gone overlooked here for far too long!!! (In case you missed it
T34C has the real answerT34C has the real answerT34CT34C has the real answer has the real answerT34C has the real ansT34C has the real answerwerT34C has the real answerT34C has the T34C has the real answerreal answerT34C has the real answerT34C has the real answerT34C has the real answerT34C has the real answT34C has the real answer
And I taught CD- and G- everything they know about sailing.
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #18 of 41 Old 07-30-2007
Seņor Member
TrueBlue's Avatar
That's what all float switches do Giu - environmentally incorrect ones have a mercury switch. But to my surprise, after buying a replacement last week, Rule has recently substitiuted their mercury swicth design with a mechanical trip device.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #19 of 41 Old 07-30-2007
Seņor Member
TrueBlue's Avatar
I type too fast - left out the e in eunuch . . .
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #20 of 41 Old 07-30-2007
Best Looking MALE Mod
Cruisingdad's Avatar
Giu,
Those float switches weigh too much for most cruisers. Plus, think about what happens when you get inverted (turtle the boat) and the switch will turn on. You will run your battery down past the 50% while you are upside down. Very serious stuff, running them past 50%. Not even your solar panels can keep up with that. Come on, get realistic.
- CD
Dear Hello,
After reading your post, I realize you have spent too much time with the Solar Stick. Return it as quickly as possible. Come back to reality. Please. Hurry. Walk away from it while you can.
- CD
HAHA!
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
