07-30-2007
Location: Dead Sea, some times called Long Island Sound
Somebody posted on an other thread that if god meant man not to sail he would have made Catalinas, or some statement like that. Check around all through hulls and sea cocks. Also was there any lightning storms before the leak? The boat could have been stuck by lightning, all be it rare, causing spider cracks in the hull (see article on Lightning in forums I think) . I had a problem with the row water side of the head, when I healed the water would go pass the hand valve but not fill the head. Look carefully at prop shaft packings and hose.
Dennis
Dennis
O'Day 302
Be careful or i will do what the voices tell me to do To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
To get the most from Sailnet, follow the link in To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 's signature. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Hey stuffit "Get a life"
