noisy wiring in mast - SailNet Community
post #1 of 11 Old 08-01-2007 Thread Starter
Question noisy wiring in mast
Is there a good way to silence my swinging vhf,masthead, and anchor light wiring without affecting the operation of my main and jib sheet halyards? The best access I see is probably through the jib halyard exit plate. The wires are making way too much noise during the night clanging inside the mast when we are trying to sleep.
rchad is offline
post #2 of 11 Old 08-01-2007
Freesail99's Avatar
I am planning on replacing the wires in my mast. It may even be my weekend project. Not sure of the best way to do it. But I am also interested in what the great minds at sailnet have to say.
S/V Scheherazade
Freesail99 is offline
post #3 of 11 Old 08-01-2007
Belliure 41'
JT1019's Avatar
Send a message via AIM to JT1019
I had the same problem. I rewired the mast and put everything into a pvc conduit that I riveted onto the mast. It’s really the only safe way to go. Due to the movement you hear I’m guessing that the wires are swinging feely and have already begin to wear off the insulation. Letting them swing around for too long could cause a short or you could loose your lighting and vhf just when you need it.
If you want pictures and directions on how I did it let me know. It was an easy project.
“Greatness Is Not In Where We Stand, But In What Direction We Are Moving. We Must Sail Sometimes With The Wind And Sometimes Against It – But Sail We Must, And Not Drift, Nor Lie At Anchor.”
Oliver Wendell Holmes
JT1019 is offline
post #4 of 11 Old 08-01-2007
Freesail99's Avatar
JT1019, I sent you a pm.
S/V Scheherazade
post #5 of 11 Old 08-01-2007
Señor Member
TrueBlue's Avatar
Are you certain the sound is from electrical wires and not rope-tailed wire halyards? We get a similar sound due to boat/mast motion, when the genoa, mizzen and main are raised up to the mastheads, exposing more halyard wire than line to the inner sides of each mast.
When the headsail is removed, mizzen/main furled and all internal halyards are clipped to deck level fittings, the noise stops - assumingly because the halyard lines are in contact, instead of steel wires.
True Blue . . .
sold the Nauticat
TrueBlue is offline
post #6 of 11 Old 08-01-2007
Regular Member
KismetP362's Avatar
If you don't want to rivet into your mast try this:
Go to Home depot and buy some styrofoam pipe insulators for hot water piping. Costs about $.99 per 5 feet. They are pre cut along one edge. Pop them open and start slipping them up over the wires. Don't forget to tape them back together after the wires are inside.
A friend of mine did this on his Ketch with hinged masts, it worked great except for the spreaders. The wires that break off from the bundle at the spreaders for the lights stopped the upward push of the foam. We have yet to have an issue with it. Here is one I found on line:
http://www.pearsoninfo.net/36-2/36-2_mast_bottom.jpg
~Ryan
~Pearson 36-2
~Sunk, Salvaged, Refitted, Sailing!
KismetP362 is offline
post #7 of 11 Old 08-01-2007
pigslo's Avatar
oversize plastic zip ties placed every few feet with the excess at different angles is a lightweight solution. Also the bottoms of plastic gallon milk jugs cut in an x and pulled over the wires is cheap andlightweight. My mast had pvc riveted to the inside.
pigslo
pigslo is offline
post #8 of 11 Old 08-01-2007
I prefer a proper wiring conduit, but the foam pipe insulator idea has merit as it can be fairly easily retrofitted, while the wire ties generally can not.
sailingdog is offline
post #9 of 11 Old 08-01-2007
Thanks Courtney.
I'm surprised no one has asked if it is a deck or keel steped mast yet. (?)
hunter Legend 37 Semper Paratus
Formerly - Tartan 34C Yawl
T34C is offline
post #10 of 11 Old 08-02-2007
WAFI
astraeus's Avatar
I've used the zip tie method as well with great results. I placed every few feet in a three pointed star formation.
Good luck, clanging wires are very annoying
Jason
S/V Astraeus
astraeus is offline
Deck vs. Keel Stepped Masts Envirella Gear & Maintenance 10 11-29-2009 11:06 AM
Deck stepped Mast-Always Bad ? Mrs Mutiny Boat Review and Purchase Forum 24 10-05-2009 07:55 PM
which 38ft boat? bluewaterdreamer Boat Review and Purchase Forum 10 10-03-2007 12:54 PM
30ft Catalina BigRuss Boat Review and Purchase Forum 3 09-09-2006 05:33 PM
Is one better than the other? gandydancer Gear & Maintenance 7 07-11-2002 06:08 PM
