08-03-2007
Siren 17
Originally Posted by tagster
what if it runs to the royal mast?
Mine are single spar, the top mast is represented by white paint, so I guess that'd make it a freshwater stay. Is it supposed to have tension?
Most likely it would be called the king stay, but since you only the one, I'd call it a salt water stay. It should have about the same tension as the back and head stays. Your main mast is propably set with a rake of so many degrees, and shouldn't move forward. If it's slouching back more then it used to be. You'd better check that the step hasn't shifted. If you want to pull it forward, you'll need to ease the back stay and the main shrouds first, then once you've pulled the mast forward. You'll need to add a shim under the bottom of the mast. If you don't have it sitting even, the mast will produce a high localized load that could prematurly wear out the bottom of the mast or the mast step.
!! WARNING !! The above information is to be used by intelligent people only. If you are Stupid, could be considered a moron, or otherwise. You are instructed to disregard this information and seek the help of a licensed and bonded professional.
