Old 08-02-2007
clayjay is an unknown quantity at this point
Where do you buy a Cutlass Bearing ?
From what I have read elswhere on here it looks as though my cutlass bearing does indeed need replacing. Where does one purchase them ?
My boat is C&C 36 made under licence her in Brisbane, Australia in 1985. The builder has long since vanished.
What are they made of, plastic.....rubber......can they be made up ??
Old 08-02-2007
SanderO is an unknown quantity at this point
A cutlass bearing is made from a bronze tube with a hard rubber liner (for lack of a better description). They obviously need to be matched to your prop shaft diameter which is a standard dimension.
Most likely the dimensions of your cutlass bearing are a standard size.
Here are websites which sells them:
http://www.mailspeedmarine.com/Produ...oductID/103247
http://www.tacomapropeller.com/dept....1=6222&l2=6223
give them a shout and I am sure they can help you out.
You will need a tool to get it out and that may be more of a problem than getting the bearing. Depends on if it is a strut etc.
jef
sv shiva
Old 08-02-2007
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Your local propeller repair facility should be able to provide any cutless bearing you need.
"Clean bottoms are FastBottoms"
First time sail boat buyer martinojon Boat Review and Purchase Forum 18 06-15-2008 09:22 PM
small and comfortable and bluewater.... can it be done jasonwillis711 Boat Review and Purchase Forum 9 07-11-2007 11:49 AM
Fischer Panda Owner''s Forum geoffschultz General Discussion (sailing related) 2 12-29-2003 10:16 PM
Installing a Cutlass Bearing Mark Matthews Gear and Maintenance Articles 0 04-26-2002 08:00 PM
Cutlass Bearing Query SailNet Gear and Maintenance Articles 0 06-06-2001 08:00 PM
