  #51 (permalink)
Old 08-06-2007
USCGRET1990's Avatar
SENIOR CHIEF
USCGRET1990 is on a distinguished road
http://www.westmarine.com/webapp/wcs...key=SiteSearch
  #52 (permalink)
Old 08-06-2007
SENIOR CHIEF
  #53 (permalink)
Old 08-06-2007
Cruisingdad's Avatar
Best Looking Moderator
Here is the first:
I like that one because you can pull the pin easily.
Here is the second. This is very similar. Ours may be a bit deeper in the barrel, but it is hard to tell from pics.
Sailnet has them here:
http://shop.sailnet.com/advanced_sea...level=0&page=2
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
  #54 (permalink)
Old 08-06-2007
sailhog has a spectacular aura about sailhog has a spectacular aura about
Alex,
Cut it in-two laterally at a 45-degree angle to prevent ingress of water, and then hinge it. Fit some thin gasket material between the two halves. It will be half as big, and you can keep it in your wallet. First remove the condoms, so that you'll have room.
  #55 (permalink)
Old 08-06-2007
eherlihy's Avatar
Finally found the needle!
eherlihy is on a distinguished road
Alex,
It appears that you have a staboard bulkhead, at the bottom of the companionway, on the other side of the door to ... (the head?). I could also see, behind the baby stuff, that there is a knee wall with a hand hold in it (there is a pillow leaning against it in your picture). It is hard to see in the picture exactly what is going on there (I would put a Nav station there if I could), but it looks as though there may be room against that bulkhead to keep the door stowed (vertically) when it is not in use. I would then be worried about scratching that beautiful cherry with the lock...
If you can provide a picture from the bottom of the companionway steps, looking starboard, it might help.
Ed
  #56 (permalink)
Old 08-06-2007
Originally Posted by eherlihy View Post
Alex,
Ed
Scratching is exactly my problem, and worse, I'd hate to see the glass door hanging in the walls.
Ed, the place where you would put a nav station if you could...is where I put my nav station!! see bellow.
As you come down the companion way, that is what I have on port side.
side view of nav station
view looking forward from nav station
On starbord side, I have the salon head at 90deg to the companion way, and the two aft cabins behind the comapnion way stairs
Here is a crude layout of my boat..sorry the quality sucks.
CD, USCG..thanks for the hinges...that seems like a good idea, I'll as Giulietta if she likes it. If she does, its a possibility. As long as I remove it when not cruising. The holes in the glass ouch....ouch....
That is not a knee high wall its more of a belly high wall. It is the aft end of the salon setee, and it curves to shape the setee, so nothing can be stowed there.
  #57 (permalink)
Old 08-06-2007
Hey..I had an idea...what if I make a drawer type thing, and the comp door stores under the salon table?? There is spave and its accessible easy enough, and out of sight!
What do you think? I can have a drawer made..
  #58 (permalink)
Old 08-06-2007
bestfriend's Avatar
Hitchin' a ride
bestfriend is a jewel in the rough bestfriend is a jewel in the rough bestfriend is a jewel in the rough
Spatial problem solving is one of my specialties. Like what to do with all the extra space in my head. If I was there, I know I could find a spot for your door!
Great men always have too much sail up. - Christopher Buckley
Vaya con Dios
  #59 (permalink)
Old 08-06-2007
wumhenry is on a distinguished road
'nother suggestion
Put tinfoil on it and haul it up with a spare halyard to improve your radar profile.
  #60 (permalink)
Old 08-06-2007
Make a padded backrest for the nav station bench, and have a pocket in the backrest to drop the companionway drop board into. That way it is out of the way, the nav station is more comfortable, and the board won't scratched, and neither will the wood.
Ideas For Keeping Cool in the Summer Heat? motorbortniker General Discussion (sailing related) 25 12-21-2009 12:12 PM
Female Cruising Companion Wanted lonelywolf Crew Wanted 4 11-26-2006 02:59 PM
A docking challenge...any ideas? FrankLanger Seamanship 8 09-10-2006 11:53 PM
Lunch Ideas (needed) sadie14 Provisioning 8 01-23-2004 12:09 PM
Sailing Companion wanted Ib Crew Wanted 1 09-14-2001 11:01 AM
