Old 08-07-2007
groundhog is on a distinguished road
Looking for a combo meter/gauge.. LCD
This is the computer age...
I just fabricated a new control panel for my boat (sapele wood hoo hoo!).
Anyway, instead of putting all of these round old style gauges back in, I am wondering if there is like one large LCD display multi-gauge that I can put in? This would be for RPM, Volts, Amps, Temp. Maybe Fuel level.
Is there an advantage to stick with the old style analog guages?
Thanks,
gh
Old 08-07-2007
Yes, the old analog gauges are easier to read in many ways. You get accustomed to where the needles should be, and then when one is off, it jumps out at you.
Also... if the one LCD panel craps out... you lose all your gauges... it is not a real bright idea IMHO to introduce a single point of failure on your instrument panel.
Old 08-07-2007
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Call me a dinosaur. I like the fancy-schmancy full-colour LCD displays, make no mistake, but it's hard to beat good ol' analog mechanical or electro-mechanical dial gauges for readability and, more importantly, reliability. The A4 on our new-to-use boat has three such old-fashioned gauges: Oil pressure, engine temperature and ammeter. Wouldn't trade 'em for the world. If one craps-out, I'll replace it with an identical gauge. (Or as nearly as possible.) Wouldn't mind havin' idiot lights and audible alarms to back 'em up, as attention-getters, tho.
Jim
s/v Abracadabra
1976 Pearson P30
Old 08-07-2007
rewell6 is on a distinguished road
SD is right, the analogs are easier to read at a glance. With a digital readout you have to read the number and think if it is right. With analog, it's just a glance.
Here is a racing trick for you. Turn all of your old analog guages so the needle points straight up when the engine is operating normally. Then it only takes a glance. If all the needles are straight up, everything's fine. If one or more is not straight up, something's amiss.
Old 08-08-2007
Ok, you have swung me back towards the analog guages.
Next question is, what brands/models would you suggest?
I would like them to all be visually similar if possible.
gh
Old 08-08-2007
why not get all one brand.... I'm sure someone makes all the gauges you're looking to replace.
Old 08-08-2007
SanderO is an unknown quantity at this point
VDO has a nice range of gauges. You can get an NEMA 2000 instrument with LCD for big buck which can display data in analog format. Add as many transducers as you want. Check out some of Panbo's finds
http://www.panbo.com/archives/cat_network_control.html
jef
sv shiva
Old 08-09-2007
resdog's Avatar
resdog is on a distinguished road
Search and ye shall find. Analog combo gauge:
http://www.boatersland.com/far-33851.html
Old 08-09-2007
resdog-
No tach on that combo gauge.. .
Old 08-09-2007
check out Autometer's site
http://www.autometer.com/cat_gaugeseries.aspx
I don't think they have a combo gauge like resdog found, but they have a dizzying selection of different styles.
