08-08-2007
You're describing a water lift muffler. It takes the place of the old style exhaust (long jacketed hoses) and works by filling with the engine cooling water. The exhaust pressure is enough to discharge the cooling water when the muffler fills and so the water in the "pot" muffles the engine's exhaust noise.
They do make them out of stainless steel, though plastic or fiberglass may be more common. I suppose it's possible to build up scale or sedimentary deposit in the water lift, but I doubt this is the issue. The much smaller engine passages would probably clog before you noticed a significant degradation at the water lift. However, you can always remove the intake and discharge hoses to see if there is any sedimentary build up.
If you have a cooling system issue, the first thing to check will be the amount of water that exits your exhaust at the transom. Is the flow normal? Note that with a water lift, the flow will sort of sputter at idle; you don't normally get a steady flow until you are running under load as it's exhaust gas pressure that evacuates the water.
It would easy to check, but I suspect you'll find the culprit elsewhere.
-Jason
