Old 08-08-2007
saltypat is an unknown quantity at this point
Galvanic corrorsion?
Hi,
I am the new owner of an old Endeavour (1983) 33. It is in the same slip where I used top keep a SeaRay 33. The Searay had a galvanic corrosion problem and the outdrives had to be replaced. I am told there is "stray current" where I am at.
The sailboat went into the water end of June. I am thinking of keeping it in the water this winter.
I have 2 huge fish I used to throw overboard for the SeaRay. Should I throw these overboard for the sailboat and clip the wire onto the stainless steel rigging? Will that be beneficial?
Clueless but learning from sailnet,
SaltyPat
Old 08-08-2007
tdw's Avatar
tdw tdw is offline
Super Fuzzy Moderator
Whatever you do I don't think that clipping to the rigging is a good idea given stainless steel's extremely poor conductivity.
Old 08-08-2007
camaraderie's Avatar
moderate?
Just put on a big honkin' shaft zinc or two on your prop shaft.
The fish only work if what they are connected to is grounded...not always true with shrouds.
Old 08-08-2007
If you want to use the fish, run a heavy cable from the boat's DC ground and attach them to it.
Old 08-08-2007
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
A zinc will only protect what it is in electrical contact with. If there is a direct electrical path from your prop shaft to your rigging, a fish zinc will provide protection. If not, you're wasting your time and money.
Since you know there are corrosion issues in your slip (or aboard your boat, which is much more likely) your best bet is to have a diver putting eyes on your running gear periodically.
"Clean bottoms are FastBottoms"
Galvanic corrosion inside winch Anjin-San Gear & Maintenance 20 06-14-2007 12:22 PM
Galvanic Isolators Gulfislander Gear & Maintenance 1 06-11-2007 05:38 PM
matching steels and galvanic corrosion khbritten Gear & Maintenance 5 03-29-2007 10:20 PM
Understanding Galvanic Corrosion Kevin Hughes Gear and Maintenance Articles 0 03-08-2004 07:00 PM
Galvanic Isolators Tom Wood Gear and Maintenance Articles 0 08-06-2002 08:00 PM
