  #11 (permalink)
Old 08-09-2007
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
FYI- Polyureathane-based sealants can attack plastics, and that is probably why 4200 is contra-indicated.
That would make sense, being as the plastic "bathtup" the transducer locks into is... uh... plastic . Thanks for clearing that up.
Jim
s/v Abracadabra
1976 Pearson P30
  #12 (permalink)
Old 08-09-2007
42ndstreet is on a distinguished road
Jim, what are you using for displays in the cockpit? I am trying to pry my wallet open to do the same project.
  #13 (permalink)
Old 08-09-2007
SEMIJim's Avatar
I'm using a Garmin 498. It's mounted on a home-brew swivel-arm that's attached to the inside cabin bulkhead on the port side of the companionway. When I want to look at the GPS from inside the cabin, I swivel it in. When we want to see it from the cockpit, it swivels out so it's sitting in the upper left of the companionway as you're looking forward.
That home-brew swivel-arm the PO made is a bit light for my GPS, which is larger and heavier than the PO's was, so I'll probably eventually replace it with one of the (more substantial) commercial products I've seen mentioned here on Sailnet before. Something that would allow us to move it actually outside the companionway entrance would be good, because, as it is, it's kind of tricky getting past it.
Btw: The Garmin 498, being last year's model, is on clearance many places. It's hard to beat for the price you can get it for right now. Comes pre-loaded with U.S. coastal and Great Lakes cartography. If you don't want the sonar, you can save a few bucks going with the 492.
Jim
s/v Abracadabra
1976 Pearson P30
  #14 (permalink)
Old 08-09-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
I mounted my 498c on my edison pedistal using a piece of teak and some U bolts.
S/V Scheherazade
Old silicone removal? AlexSchmoll Gear & Maintenance 5 12-09-2006 07:26 PM
Removing Silicone seatrek Gear & Maintenance 3 05-18-2004 05:59 AM
removing old silicone caulking bmcald Gear & Maintenance 3 03-20-2003 04:26 AM
Silicone bottom paint? VIEXILE Gear & Maintenance 2 05-16-2002 10:30 AM
