08-12-2007
"Sparkie"
haffiman, you beat me to the warning. I made this mistake on a Volvo diesel and filled one cylinder with water through the exhaust valve while the engine was not running. Took me most of a day to get the water out and the engine running again. BTW, if you think you might have put even a little water in the cylinders, DO NOT START THE ENGINE!! Water will not compress, and you will break something. Use the bucket and let the water pump pick the water up the way it is designed.
DD
