08-10-2007
"I'm told you're not suppose run diesels without putting them under load, but "
So if you don't run diesels without a load, how do you charge your batteries when cruising under sail? How do you cool those marine refrigerators sold that use a compressor powered off the engine while at idle? I have not been a cruiser, so I cannot say it never damaged my engine, but I knew a man who had one of those refrigerators for nearly 20 years, sold the boat, and it is in the slip next to mine with the original engine. No damage to the engine that I can see! I really need to know why one should not run a diesel without a load, because after I retire I plan to live on my boat, often sitting at anchor for a couple days due to inclement weather and/or laziness! I will need to charge my batteries. I bought a 105A alternator for my engine; are you saying I must buy a seperate genset?
