08-10-2007
As for buffers... look HERE.
For the deck, at least the non-skid portions, use Woody Wax. For the hull, the 3M Cleaner & Wax is pretty good if your boat needs some TLC, but if it is in pretty good shape, you can try Meguairs... or if you want something that takes a bit less work, try the West Marine wax that did pretty well in PS tests IIRC. More waxes here.
