08-10-2007
The SA/D of your boat is a bit on the low side, at 16.28 or so.
However, increasing the boom length and sail size will move the Center of Effort aft, as pointed above and may cause some issues with the sail/keel balance—weather/lee helm, etc.
It may also require you to increase the size of the running rigging, since the additional sail area will impose greater loads on the mainsheet, traveler, boom vang, etc. It may also present more of a risk of snapping the boom, which sounds like it is a mid-boom sheeting setup—unless you get a larger spar—since mid-boom sheeting presents higher loads on the boom than end-boom sheeting does.
Finally, adding all this weight aloft—new, longer, larger boom, larger mainsail, possibly heavier rigging, etc—will reduce the stability of the boat a bit... since the more weight aloft you have, the more tender your boat will be.
