Old 08-12-2007
drynoc is on a distinguished road
Sea **** handle
The handle on the raw water sea **** on my boat is vertical when it is open, but lately the vibration of the boat in motion is causing that handle to fall ever so slightly. It hasn't happened enough to shut the valve, but I'm concerned about it getting worse. Otherwise the sea **** is fine - no leaks or any other problems. Any suggestions?
Old 08-12-2007
Artwerke is on a distinguished road
On some sea cocks you can tighten the nut on the other side of the valve from the handle to increase friction. Art.
Old 08-12-2007
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
If tightening the nut doesn't work, you could tie a little keeper line around the handle to keep it in the open position, BUT you need to use very light line that can be easily cut or broken if disaster strikes and you need close the valve in a hurry.
Old 08-12-2007
Don Radcliffe
donradclife is on a distinguished road
If your handle is falling over on its own, you need to check whether the valve is working at all. I installed a new set of ball valves 2 years ago, and found out that one of them has failed internally--the handle and the shaft it is on no longer turns the ball, which is stuck half-open.
Old 08-12-2007
CapnHand's Avatar
humble pie rat
CapnHand is on a distinguished road
Shock cord (bungee) might work well in this instance for a temporary fix. Replace the valve at the next opportunity. Not a good idea to leave a lot of temporary fixes on a boat, especially below the water line.
Old 08-12-2007
Right, but I don't know that I would do a mid-season haul for this one thing.
Old 08-12-2007
CapnHand's Avatar
humble pie rat
Yes, and swapping it out while the boat is in the water would be ill advised, so his next haul out would be the next opportunity.
Old 08-12-2007
Thanks for the help. Next time I'm at the boat, I'll start the engine without opening the valve to see if it is working properly. Then I'll try tightening that nut to see if that will tighten the handle. I'm going to haul this winter anyway, and I plan to replace it then. But I plan to do a lot of sailing between now and then.
In Search of Sea Room Micca Hutchins Seamanship Articles 0 03-26-2002 07:00 PM
Sea Snakes Ralph Doolin Seamanship Articles 0 01-21-2002 07:00 PM
Sea Snakes Ralph Doolin Cruising Articles 0 01-21-2002 07:00 PM
