08-13-2007
Originally Posted by dsbentley
sd, I agree with what you are saying, but I question the fact that the boat has been working fine with this configuration for 20 years so something has recently changed. I know there is no other leak's as I have monitored the bilge and see nothing else coming in. The check valve is very low near the pump, so I dont think I am hearing the gurgling sound from the CV. It is possible that the CV may be taking a while to break then when that happens, I am hearing the gurgling from the siphon?
You could be hearing the gurgling noise from the leaking check valve traveling up the hose to the anti-siphon valve.
I think a 2nd pump would be a good idea, would you install this pump lower than the bigger one, or just raise the float switch on the big one so the small pump would kick on first? Is there a way I can use the same discharge threw hull for both pumps?
Install the pump as low as possible, and raise the float switch on the bigger pump...that way the small pump runs for the maintenance "bilge pump" work, and the larger one kicks on only when the water starts exceeding what the little one can handle.
If the hose to the through hull slopes downward from the anti-siphon valve, which I believe it will, you could put a T-fitting in it, and use it for both, but you'd need a anti-siphon valve in the smaller hose as well, and it should rise to the same height as the anti-siphon valve in the larger one.
