Reef Points - Page 2 - SailNet Community
post #11 of 15 Old 08-13-2007
nightowle's Avatar
Bardo....Any online articles?
if you found any online articles about reefing; please post the links if you can. I'd be very interested.
Thanks.
________
S/V Don't Panic!
O'Day 27
Seattle, WA
“Navigare necesse est, vivere non est necesse” To Sail is vital, to live is not.
nightowle is offline
post #12 of 15 Old 08-13-2007
Helms ALee!
tenuki's Avatar
keep your reefing line/s separate from the reef sail ties. Usually the 'ties' are sewn into the sail. Their purpose is to keep the loose sail at the bottom after you reef from flogging. They will rip your sail out if you use them for anything else.
The reefing lines run through the large gromets at both the tack and the clew points of the reefed sail. In both cases you usually tie one end of the line through a padeye using a stopper knot, thread it up through the reef point, then down to the other side where it is cleated off. A lot of times for smaller 'jiffy reefed' boats there is a block near the end of the boom that leads it to a cleat midway on the boom. At the mast it is common to have both the padeye and the cleat on the mast so that there are forces forward to keep the tack close to the mast.
Here's a pic from the R20 tech manual that describes what I'm talking about.
tenuki is offline
post #13 of 15 Old 08-13-2007 Thread Starter
Just another stop...
Bardo's Avatar
Nightowl,
The articles that I referenced are on Sailnet, and I found them very informative. Although, as I said, I love the varied and highly experienced input that I get from our shipmates on the forum. Search on the articles section to view them.
Freeman
Bardo is offline
post #14 of 15 Old 08-14-2007
nightowle's Avatar
Thanks, Bardo. I agree: the information here is invaluable. I'll check out the articles.
________
S/V Don't Panic!
O'Day 27
Seattle, WA
post #15 of 15 Old 08-14-2007
pirateofcapeann's Avatar
[quote=sailingdog;179343]IMHO, you don't generally need to tie in the reefing points unless you're going to be reefed for an extended period of time. If you're just reefing for a brief summer thunderstorm, I wouldn't bother tieing off all the reef points.quote]
Sorry. I have to disagree. Make those points any time you tuck a reef! Even a short 50 knot blow will flog that bunt and shake the hell out of the rigging! Also, those little summer squalls can dump a hell of a lot of water and fill that pocket amazingly efficiently, resulting in a lot of excessive strain on the rig and can even greatly diminish the stability of the boat!fficeffice" />>>
________________________#\__
"Who would go to sea for pleasure
would go to hell for pastime."
PoCA
pirateofcapeann is offline
A question about reef points parttimesailor Learning to Sail 9 06-19-2007 12:40 AM
The Basics of Reefing Mark Matthews Learning to Sail Articles 0 03-29-2004 08:00 PM
The Basics of Reefing Mark Matthews Seamanship Articles 0 03-29-2004 08:00 PM
The Basics of Reefing Mark Matthews Gear and Maintenance Articles 0 03-29-2004 08:00 PM
The Basics of Reefing Mark Matthews Cruising Articles 0 03-29-2004 08:00 PM
