Old 08-13-2007
bhcva is on a distinguished road
Seaclear assistance needed
I have loaded Seaclear and it's associated GPS interface on my W98 laptop. Everything seems to work ok including the interface to the GPS (Garmin 76), but I have been unable to get it out of DR mode. It shows a chart where the boat had been manually placed earlier, not where the GPS indicates it is now. This has all been done at the dock so there has been not actual movement of the boat, but surely the current location would be shown and Seaclear would go out of DR mode?? I know there are some restrictions in Win98, but I wouldn't think this would be one of them.
Any help would be appreciated.
Thx, Bruce
Old 08-13-2007
GySgt's Avatar
Semper Gumby
GySgt is on a distinguished road
Send a message via MSN to GySgt
That usually indicates no GPS data, anyway to test your GPs outside of the program?
After thought: How does your GPS connect USB? or serial, if serial, null modem or straight thru?
Old 08-13-2007
Did you set the Garmin up using a NMEA 0183 serial cable? If you tried to use the USB port and cable, it won't work. The USB port on the Garmin only outputs Garmin proprietary code—you have to use the serial NMEA 0183 port. BTW, you also have to set the port on the Garmin to output NMEA 0183, since it defaults to Garmin's own proprietary code. Set the serial port to NMEA 0183, 4800 baud, 8 bits, 1 Stop bit, No parity.
Then the laptop should be seeing it. To check, run Hyperterminal and see if you can read the serial port and see the incoming NMEA 0183 sentences from the GPS.
Old 08-13-2007
BarryL's Avatar
BarryL is on a distinguished road
Tools | System | NMEA Input Monitor
Hello,
To see what (if anything) your laptop is receiving, in Seaclear go to
Tools
then
System
then select NMEA Input Monitor
If your are receiving data it will show up.
Did you set up seaclear for the GPS info?
Move the mouse onto the chart and right click. Then select tools and comm. Verify you have the correct com port and baud rate.
Good luck,
Barry
Barry Lenoble
Day To Remember, 1986 O'day 35
Mt. Sinai, NY
Old 08-14-2007
thanks for all the replies
The connection is serial via a garmin cable.
The g7 program and Seaclear both communicate successfully with the gps...would that not imply that the location data would be transferred as well as route and other textual info?
The gear is on the boat so I will check your suggestions when I get back there.
What is the hyperterminal?....g7??
Thx, Bruce
Old 08-14-2007
Hyperterminal is a standard windows terminal program. It can be used to see what data traffic is coming in over the various serial ports.
Old 08-14-2007
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
My Nobeltec chart program and Garmin required a serial port. So you have to get a program that emulates a serial port before you can use the USB ports. Now every thing works great.
Old 08-21-2007
Problem solved
Setting the Garmin to NMEA solved the gps data problem...thanks.
It seems that the g7xxx program and the seaclear program will only communicate with the garmin to get routes, positions, etc if the garmin is set to Garmin.
Bruce
Old 08-21-2007
Bhcva-
Glad to help... Don't know why Garmin sets their units to default to Garmin protocol....very annoying.
Format of Garmin nautical maps - Seaclear?? Northeaster Gear & Maintenance 14 06-25-2007 04:55 PM
No hunting needed for legendary Easter eggs - Macon Telegraph NewsReader News Feeds 0 04-07-2007 04:17 AM
6-pack needed in Bahamas?? Carbonbody Chartering 0 09-14-2004 11:48 AM
Bad situation/Escape assistance needed nofixedplans Cruising & Liveaboard Forum 2 05-11-2001 01:51 PM
Gear/Rig needed for Asym. Spinn? jrd22 Gear & Maintenance 8 02-22-2001 04:33 PM
