Old 08-13-2007
wumhenry is on a distinguished road
Unhappy unclogging toilet
I can still flush the Raritan PHII toilet on my boat into the holding tank, but the overboard waste line is clogged. Apparently because someone violated the rule against flushing paper products other than TP. (A female passenger sheepishly confessed to that dereliction under the relentless pressure of a rigorous inquest in the spirit of Captain Queeg's stolen-strawberries investigation in *Caine Mutiny*.)
What's the drill, marine plumbing experts? What should I try first?
Old 08-13-2007
CapnHand's Avatar
humble pie rat
CapnHand is on a distinguished road
Try getting the offending female to fix it.
Old 08-13-2007
Disconnect the hose at the highest hose clamp, and hopefully it is above the waterline—and use a coat hanger to try and remove the obstruction. It won't be pretty, and IMHO, the offender should be made to do the work, but that never happens...
Old 08-13-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
Tip of the day - Wear a respirator.
S/V Scheherazade
Old 08-13-2007
There'll be no such justice this time, either, because the offender is on back on dry land and has skipped the state.
If the coat hanger doesn't work, what's the next step? Disconnect the same hose at the other end, too?
Old 08-13-2007
Depends on where the clog is. If the clog is at the seacock...removing the hose is a bad, bad idea. If it isn't at the seacock, then removing the hose is a good next step, after closing the seacock.
BTW, Clorox bleach wipes, heavy long rubber gloves and a full face-mask respirator are probably a good idea... and contractor grade trash bags...
Old 08-13-2007
Cruisingdad's Avatar
Best Looking Moderator
I guess you could try a snake???? Carefully?? That is probably what I would do. You can buy them at Home depot or Loews.
Just a thought. Dont tear that hose though!!
- CD
Catalina 400 Technical Editor
Catalina 400, HN#289
Com-Pac 16
Old 08-13-2007
Then maybe I should start at the seacock, no?
Old 08-13-2007
Surfesq's Avatar
Surfesq is on a distinguished road
Dude: Look, this is why there is this thing called, "The Help." Call the Marina Office and pay someone to fix it. Unless of course you look good in brown.
Old 08-13-2007
Surf-
Is that how you got so much work done on that previous boat of yours???
Lavac toilet seat seals Soutie Gear & Maintenance 11 10-06-2006 10:26 AM
The Foolproof Head James Baldwin Gear and Maintenance Articles 0 10-25-2004 08:00 PM
Consumed toilet paper welch Cruising & Liveaboard Forum 6 06-09-2004 04:01 AM
toilet replacement richard46 Gear & Maintenance 4 07-29-2002 03:39 AM
Toilet Ethan_nyc Gear & Maintenance 1 07-10-2001 02:10 PM
