08-13-2007
I disagree.
A DC-only unit is generally a bad idea, especially if you plan on keeping it on all the time.
Using a DC-only refrigerator means that you have to leave the battery switch on while the boat is unattended. If a power outage occurs, that means the refrigerator is now going to be draining the battery banks for whatever the duration of the power outage is... if you have a leak, the bilge pumps will have a much shorter running time due to the loads caused by the DC-based refrigerator.
If you have a dual voltage unit, then you don't run into this problem, since the DC system can be turned off, leaving the fully charged batteries for the bilge pumps alone. Granted, if the power goes out the food in the unti will spoil, but I'd rather risk spoilage than the boat sinking.
Originally Posted by JohnRPollard
If you have a battery charger that runs off shore power, for simplicity's sake I would just stick with the DC unit. If you don't have a battery charger, I would still stick with the DC unit and use the savings to get a battery charger.
And yes, the MT60 combi unit is the only one that can be set as both refrigerator and freezer AFAIK.
