Old 08-14-2007
dmoreau is on a distinguished road
Seaclear
Ive downloaded seaclear and g7towin i dont sem to be able to load g7towin into the seaclearii directory (how do i do this).is there any special way to connect the gps to my laptop to get it to work.Ive got the maps but cant seem t get a reading from my gps(garmin 276c)
Thanx
Doug
Old 08-14-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
Doug, there was another thread on seaclear yesterday. You may want to have a look at it. I hate to admit this, but reading the manual has helped me in the past.
S/V Scheherazade
Old 08-14-2007
Lancer28's Avatar
I'm the FNG still...
Lancer28 is on a distinguished road
Doug, I don't know that garmin very well, is it a NMEA receiver? I use seaclear and just a GPS antenna ($30), I have to go in to the program and under "comm" change the com port adress to what the USB replicator is outputting.
Old 08-14-2007
dmoreau-
Again, as I posted in the other thread..
Garmin GPS units default to a Garmin proprietary protocol. For them to be recognized by other software packages, you need to set the port your on to the NMEA 0183 protocol at 4800 baud, 8 bits, 1 stop bit and no parity. The 276 has two serial port outputs IIRC.. so you need to make sure that you've set the one you're using or set both to the NMEA 0183 protocol.
Oziexplorer vs Seaclear 2 - Experience?? Northeaster Gear & Maintenance 2 05-01-2009 09:11 PM
Seaclear assistance needed bhcva Gear & Maintenance 8 08-21-2007 11:32 PM
Laptop Nav. Garmin GPS18 and blue charts?! Lancer28 Gear & Maintenance 7 08-07-2007 04:11 PM
Format of Garmin nautical maps - Seaclear?? Northeaster Gear & Maintenance 14 06-25-2007 04:55 PM
SeaClear II PC Connections blacktie General Discussion (sailing related) 1 01-20-2007 02:43 PM
