08-14-2007
Moderator
Hi Jeff,
As I said in the other concurrent thread, I like the DC fridge units for simplicity's sake. But even if you're already committed to a DC unit, there are still a heck of a lot of choices/variables.
We have a Frigiboat keel-cooled fridge on our boat. A previous owner had it professionally installed and we really like it - power draw is very low. But I've read of some newer designs by other vendors that have holding plates rather than just an evaporator plate. If I were installing now I'd be inclined toward that kind of unit.
Down here on the Chesapeake, it gets quite hot in the summer so it's nice to have the heat dumped out of the boat through the heat exchanger. Conversely, it's cold enough down here that we have to winterize, and thankfully the keel-cooled Frigoboat requires no winterization. So that is one variable that may apply to you as you consider whether to go with a water-cooled, air-cooled, or keel-cooled unit.
The air-cooled kits tend to lose some efficiency as the ambient temps increase. But they are probably the easiest to self-install (I helped stick one in a friend's boat and it wasn't very dififcult). Some folks have the fan blowing into the wet locker to provide dry heat for foul weather gear, etc, but ultimately the heat stays in the boat. Maybe there'd be a way to duct it outside, but up in New England this may not be a big deal.
I'm not an expert by any means, but just thought I'd pass along a few considerations that have affected/occurred to us.
