Old 08-19-2007
cpr66 is on a distinguished road
Stuck Waste Cap
Can't remove my waste cap and the inner "star" key hole is stripped.
Any ideas on how to remove it?
Thanks
Old 08-19-2007
redcorvette1995 is on a distinguished road
Drill two holes through the cap.
Use a bung wrench (like the kind for a table saw, or circular saw, with two pins through it) to twist out the cap. Replace the cap.
Old 08-19-2007
mike dryver is on a distinguished road
use a cold chisel. grind a good sharp edge on it and drive it into the cap at an angle about a 1/4" from the edge in the direction to loosen it. make sure you spray some penetrating oil around thread area first. gently tap cap to jar it a little then use chisel
Old 08-19-2007
Stuck Waste Cap
Don't know if it will turn, but I'll give it a try. Thanks
Old 08-19-2007
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Maybe combine the two methods and drill a hole in the cap to give the chisel a place to get a bite.
"Clean bottoms are FastBottoms"
Heat exchanger cap partial failure Valiente Gear & Maintenance 9 06-01-2007 12:09 AM
Replacement cap for the diesel fuel filler inlet? jackdash Gear & Maintenance 1 06-14-2006 11:13 PM
Man, dog rescued from sailboat stuck off Va. Beach - WVEC.com (subscription) NewsReader News Feeds 0 04-26-2006 06:15 PM
Self-steering gear options: Cap Horn? VIEXILE Gear & Maintenance 1 05-12-2002 07:03 PM
