Old 08-19-2007
Zogumwesterly's Avatar
Zogumwesterly is on a distinguished road
LED running lights
Can anyone give me advice on LED running lights. I am interested in tricolor, stern, and bow lights. I have heard that some of the masthead LEDs are on a similiar frequency to VHF and makes communication ineffective. Thanks in advance.
Old 08-19-2007
Zogum-
LED's don't operate on a frequency that interferes with anything... they're diodes... I have the Orca Green Marine Tri-Anchor w/ strobe. It works beautifully, and doesn't interfere the VHF at all.
I am looking at getting the steaming, stern and bow lights later this year.
The energy savings is great... I've run the anchor light all night with the refrigerator and had the battery go from 12.6 volts... to 12.6 volts... BTW, the house bank is 220 Amp-hours, and the fridge is an Engel.
Old 08-19-2007
hellosailor's Avatar
It is not that any of the LEDs are "on a frequency" but that some of the light assemblies have active electronics to control the LEDs and there have been reports of some of them emitting RFI (radio frequency interference) with VHF antennas mounted next to them.
At this time it is uncertain if that is a real problem, coincidental, or simply a faulty LED fixture that is causing the problem. Your best bet would be to decide which fixture you want, and then ask the manufacturer directly if there is any possible RFI problem with their equipment. When you go to install it, power it up and tape it in place and call down below, have someone else check the VHF to make sure there's no problem before you complete the installation.
An LED "replacement bulb" can't create RFI at all--unless there are active control electronics in it.
Old 08-19-2007
HS-
I've got mine mounted about six inches from the VHF antenna... no problems...
Old 08-19-2007
Thanks for the quick reply, I'm looking at the lopo lights I think that's what there called. It's good to know that people trust them.
Old 08-19-2007
By the way SD, I have a seafrost reefer system. Do you think that it is worth converting over to one of those Engel things? Thanks, Briggs
Old 08-19-2007
The Engels are self-contained portable refrigerators. I don't think you can convert your existing system over to one.
Old 08-20-2007
Valiente's Avatar
While they are beautiful works of art, there are far less expensive alternatives in Colregs-level marine nav lights, including the option to buy just the bulb assemblies...they plug right into the bayonet mount. This is probably how I will go, as I have Perkos up and down.
http://firststarled.com/products.html
http://www.orcagreen.com/
Old 08-20-2007
Valiente-
Just be aware that the replacement bulbs have not been USCG certified in any fixture to date. That could leave you open to some serious legal liabilities if you were hit while using them, as you could be considered to be operating without the proper navigation lights. The Lopolight and Orcagreen Marine fixtures are USCG certified.
Also, the FirststarLED fixtures use a PWM controller chip and may be more likely to exhibit the VHF interference that was mentioned previously. YMMV.
Old 08-20-2007
Lancer28's Avatar
I'm the FNG still...
Lancer28 is on a distinguished road
Sailingdog, could you please post a part # list of your LED bulbs that replaced the standard ones? I've been looking, but I can't seem to find the right things.
I really wanted to do all of my interior lights and running lights. The hardest one to find that I'm looking for is the 25W international light on the masthead. I can't seem to find anything bright enough to make it.
LEDs afloat GoodOldBoat Gear and Maintenance Articles 18 1 Hour Ago 03:15 PM
Bow and Stern Running Lights Duke 7184 Morgan 1 11-14-2006 06:54 PM
LED running lights JohnDrake Gear & Maintenance 1 08-23-2003 11:55 AM
Kerosene Running Lamps Sue & Larry Gear and Maintenance Articles 0 07-04-2002 08:00 PM
Running Lights SailNet Seamanship Articles 0 06-21-2002 08:00 PM
