Old 08-20-2007
Vets
dennisvetter is on a distinguished road
Leak at hull/deck or toerail
I own a 1970 C&C 30' Redwing. On a recent cruise we had quite a bit of water in the V-berth after beating into some pretty good sized waves. I've been able, thus far, to isolate it to EITHER the hull/deck seam OR the bolts which hold the teak toerail on. My next step is to remove the toe rail, seal up the bolt holes, and try my high-pressure water test again. If it leaks, it's most likely the hull/deck seam (I can't imagine what else it would be). If it doesn't, it's (yipee) only the toerail bolts.
Two questions:
1) Is this the best way to isolate the point of infiltration?
2) If it's the hull/deck seam, I'm a bit leery of removing the rub rail. Does anyone have any knowledge of how this is fastened and if I'm going to be hosed myself (pun intended) if I pull a section of it away so I can seal the seam?
Old 08-24-2007
CatSailor from Oz
alanl is on a distinguished road
Send a message via Skype™ to alanl
You might find some interesting articles on leak fixing at www.handymariner.com,au These do not deal specifically with your hull-to-deck join problem, but might help to get some ideas
Cheers
Alan, Sydney
Old 08-24-2007
engcon's Avatar
engcon is on a distinguished road
Allan
Link is broken
Old 08-24-2007
Engcon-
He fatfingered it...has a comma instead of a dot. it is www.handymariner.com.au
Old 08-24-2007
camaraderie's Avatar
moderate?
One technique for finding leaks involves putting soapy water all over the suspect areas and pressurizing the cabin with an industrial type fan in the companionway. You will see bubble blowing where the problems are.
This may save you some unnecessary destruction of the rail or deck. Good luck!
Old 08-24-2007
Here .. Pull this
Sailormann will become famous soon enough
The 35 predates C&C’s extensive production of cored hulls, and the hull is made of relatively thick, solid, hand-laid-up fiberglass. However, the deck is composite with a balsa core. The hull and deck are joined on a standard flange and bonded chemically and mechanically.
Leaks are a common ailment in most 35s, particularly at the hull-and-deck joint and around the portlights. Bedding compound that has lost resiliency primarily causes these leaks.
If you find that your leak is in fact the joint, then the flange is probably the easiest type to repair. Basically - you just need to pry it apart very, very carefully - take a piece of the goop that's in there and see if you can find it, or something similar, clean out the area and put more goop in.
If you love the boat, then you might want to consider tabbing the joint with glass and epoxy, all around from the inside of the boat. Lots of work but it will seal and hold.
There is probably someone who has dealt with this issue in one of the groups listed here:
http://www.cncphotoalbum.com/
Old 08-25-2007
This is an excellent way to do it... but you do have to thoroughly seal up all the vents and ports for it to work, and generally need to seal the companionway around the fan in some way. When I did this last, it was on a CD30 with a big industrial floor dryer squirrel cage fan, and the output vent was about 18" x 4" and we made up a foam-core drop board to use with it and duct-taped it in place. Duct tape sealed all the vents and ports too. I awa amazed at how many cabin to deck leaks we found.
Old 08-25-2007
SimonV's Avatar
Wish I never found SN!
SimonV will become famous soon enough
You can use a yard blower on one of the vents after sealing the boat with duct tape.
Simon
Ericson 39B.
I love my boat
S/V GOODONYA
Brisbane
present location Brisbane Queensland
DELIVERY SKIPPER
Installed Teak Toerail & Cockpit Seats 1970Columbia34 Gear & Maintenance 10 05-28-2009 04:18 PM
Odd coolant leak issue Valiente Gear & Maintenance 12 05-08-2007 12:14 PM
Exhast Leak / Wrap Material? 1970Columbia34 Gear & Maintenance 11 05-01-2007 04:19 PM
Yanmar Fuel Leak jnj Gear & Maintenance 3 07-19-2005 12:41 AM
The Dreaded Keel Bolt Leak Mark Matthews Gear and Maintenance Articles 0 04-07-2002 08:00 PM
