water in engine oil?!?!? - Page 2 - SailNet Community
post #11 of 21 Old 08-21-2007 Thread Starter
Thanks everyone! This is my first sailboat purchase and I've learned a lot from these forums. This boat was already priced quite low and, while there are many C400's out there, most are newer and quite a bit more expensive (read: out of my price range). Buying one that is older and maybe has a few manageable issues is the only way I can really get into a boat this size.
I think this answered my question of how the water mixed with the oil - that it was a result of the cranking and it actually came through the exhaust valves via the muffler (that is a really bad design if water intrusion is possible simply from cranking). So I gues it may be unrelated to the bad heat exchanger as that would only allow the coolant and water to mix if it was cracked. I will have to research this a bit more an be confident I understand how the water got in, how long it was in there, and how it was fixed. I'm still a little confused because the oil was supposedly changed yesterday - after the cranking problem and after the heat exghanger was replaced. So, the water must have come in after the oil was changed and there shouldn't have been a crancking problem at that point.
I'm quite torn on this. On one hand, I can totally see just walking away. On the other hand, if this hydrolocking problem is not uncommon and it was quickly found and resoloved without sustaining substantial damage (to be verified in an engine survey), then there is a price at which I am comfortable buying this boat. I would probably just back out the value of the engine entirely - so that every month/year that the engine lasts is a pleasant surprise. That leads me to a follow up question: what is a 38hp westerbeke with 850 hours worth? If a new engine with all the trimmings is $15k, then perhaps the answer is half that - $7500.
sorry - i must have accidentally double posted this thread. the first time i clicked post i got an error - so i just clicked it again...
msbam207 is offline
post #12 of 21 Old 08-21-2007
Owner, Green Bay Packers
Get an estimate on the deck repair.
Price out a new engine.
Compare the boat's price to others for sale.
Consider what "the rest of the survey" may show.
If your price point is tight and you buy this particular boat, how do you plan to deal with the fact that you may not be sailing until you raise the money to get this boat fixed? Not that this boat will be just sitting not costing you money in the meantime.
I am no expert, but I generally consider 1000 hours about the time that you will have to start putting money into a diesel engine, in $2-300 chunks. Alts, pumps, etc.. start to show wear.
I would be approaching this boat as an immediate canidate for plan B, and that ain't the sailin' plan. Plan A includes the engine ok, the deck is fixed for less than 2 grand, nothing else is seriously wrong, and you got an accurate survey. If you can deal with Plan B-buying a motor, fixing the deck correctly, waiting to sail for a year or so, and anything else that comes to light-I might buy the boat. If you are counting on Plan A, don't buy it.
Wm. F. Buckley, Jr.
sailaway21 is offline
post #13 of 21 Old 08-21-2007
Omatako's Avatar
The info on the water in oil siuation seems a little vague. I don't know of any situation where a compromised heat exchanger will put water
in the oil unless there is a specific heat exchanger to cool the oil (unlikely). This sounds like a head gasket blown beteen an oil gallery and the cooling system.
Walk away? Well, maybe you can discuss a price reduction that sees an economical repowering of the boat remembering that there will be an element of betterment that you shouldn't be too reluctant to participate in financially. If there is a partial contribution from your side, evaluate the benefit of having a new engine.
If there is no contribution from the seller or if this is not the only serious defect then I agree with several other posts - walk away.
Andre
Omatako is offline
post #14 of 21 Old 08-21-2007
Weighing-in, here...
Moisture detected in the core may or may not be a serious issue. It is an issue that needs to be addressed, in that the incursion at least needs to be stopped. If there was too much moisture for too long, rot will begin and then more serious repairs may become necessary. It sounds like you have at least one such spot on the boat you're considering. Our boat had no soft spots, but the entire aft 1/3 of the cockpit sole had very high moisture readings. High enough that the surveyor was confident that, tho it wasn't soft now, it certainly would be before too much longer. So, before we repaint the decks, we'll be having that torn up, re-cored and re-glassed.
To me, the bigger issue is the engine. Water in the oil is a Very Bad Thing. I suspect a blown head gasket. You need a thorough engine inspection by a qualified marine mechanic, to include engine oil analysis and compression test.
Jim
SEMIJim is offline
post #15 of 21 Old 08-21-2007
Best Looking MALE Mod
Cruisingdad's Avatar
msbam,
I am the C400 Tech editor. I will PM you.
- CD
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
post #16 of 21 Old 08-21-2007
Learning the HARD way...
eherlihy's Avatar
Walk away...
I have to weigh in on this... If it was my money, I would walk away, unless the seller were to spring for a COMPLETE engine rebuild. The fact that you had to ask about the water in the oil shows that there is smoke here, and it's not just comming from the engine... How did the current owner suddenly forget to preheat the glow plugs after 800+ hours?
While the heat exchanger may have needed to be changed, it alone is not the cause of water in the oil. The lubrication and cooling systems are supposed to be seperate. Actually there are TWO cooling systems in most modern diesels; raw water and fresh water. The heat exchanger is where the raw water and fresh water cooling systems meet. Heat is drawn off the engine into the fresh water system, and it passes through the heat exchanger to, you guessed it, exchange it with the raw water system. The now cooled fresh water is returned to the engine to be heated again, and start the cycle all over. The raw water system runs this now warm water into the exhaust elbow, which cools the hot exhaust gasses, and then falls into the water-lift muffler. As exhaust continues to enter the muffler it blows bubbles of water, and exhaust out the transom exhaust pipe.
Hydrolocking can occour if the engine is cranked over too long (like +1min.) without the engine starting. What happens is that the waterlift muffler gets full of water, which then backs up the exhaust to where it can enter a cylinder when the exhaust valve opens. When this happens, because water does not compress, water is forced to take the path of least resistance, and the engine experiences tremendous wear. The path of least resistance can be bypassing the rings (doubtful), pushing out the head gasket, or cracking the block. Any of these would inject coolant water into the engine oil. All of these are expensive to fix. In addition there is a tremendous strain on the connecting rod, the bearings, even the crankshaft, which may manifest themselves over time in drastically shortened engine life.
It seems more likely that this engine has had an overheating problem that resulted in a warped (possibly cracked) engine block. The replacement of the heat exchanger treated the first problem, but not before the second problem manifested itself. I would be very curious about the status of the fresh water system. Is there any oil mixed in there (this would appear milky, or foamy)? If so, you have a leak between the fresh water system and not the raw water system. You could do a compression test on each cylinder, which would help localize the problem... but why?
Walk away, or get a complete engine rebuild at the seller's expense.
Ed
Last edited by eherlihy; 08-22-2007 at 01:37 PM. Reason: Confused author: Raw water .NE. Coolant
eherlihy is offline
post #17 of 21 Old 08-21-2007
Given that you are still inclined to go aheard with this boat and you and the seller compromise on a selling price based upon currently known damage, I'd suggest you consider two options, the first being the riskier of the two:
1. Stipulate in the contract that the seller be responsible for an agreed-upon amount of repair costs beyond that which you and the seller agree to for the actual selling price, or
2. Escrow a portion of the agreed selling price pending a reasonable trial period during which you can be assurred the engine damage is known.
The latter option would minimize you litigation risk
k1vsk is offline
post #18 of 21 Old 08-21-2007
eherlihy's Avatar
Oh yeah, pulling the valve covers should NOT show if there is any damage related to this problem, but it will cost (somebody) money.
Also changing the oil, while usually a good thing, could, in this case, mask the problem.
eherlihy is offline
post #19 of 21 Old 08-21-2007
eherlihy's Avatar
Finally (and I promise to shut up after this), a "new engine with all the trimmings may be ~15K, but the installation will add to that. The guy that runs my sailing club has told me that he spends about ~$12K on a complete *rebuild* for his fleet of 30-40 foot boats.
eherlihy is offline
post #20 of 21 Old 08-21-2007
Moderator
Jeff_H's Avatar
Water in the lube oil is more likely the result of a blown headgasket which can be caused by filling the cylinders with water as described above, but a blown headgasket can also be caused by overheating the engine. If the engine really was hydrolocked, there is likely to be damage to the valves, injectors, main crank and bearings, and perhaps pistons and connecting rods, and maybe the starter motor and flywheel. In other words the engine would not appear to run normally.
The heat exchanger is probably a separate issue. I can't see how the heat exchanger would allow water into the crankcase unless that model also has an oil cooler.
I would agree with the suggestion that you plan on walking away from this particular boat, or else come to an agreement that reduces the price of the boat by the cost of a new engine in place. I say in place because pulling an engine out of a boat and then installing and realigning an engine is a pretty big line item.
Good luck,
Jeff_H is online now
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Engine Oil Problem soylentgreen Gear & Maintenance 4 08-16-2002 10:17 AM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
