Old 08-21-2007
SENIOR MEMBER
seamyst is on a distinguished road
leaking fill valve
Has anyone changed out a fill valve on avon dinghy? I have a small leak and want to repair.
Old 08-21-2007
If it is like the fill valve on the Achillies I have, it shouldn't be a big issue. The valves on the Achilles dinghy screw into a plain threaded opening/port in each air chamber. The valve has a inner insert that unscrews so you can fill the dinghy and has a one way flapper valve in the body of the valve.
Old 08-22-2007
SENIOR MEMBER
Thanks, Sailing Dog. I must have a similar type it has a screw type fitting. I was hesitant to remove until checking with someone. I can now eliminate the small leak.
Old 08-22-2007
TrueBlue's Avatar
Señor Member
TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough TrueBlue is a jewel in the rough
My inflatable has a Halkey-Roberts valve, which I believe is the standard for most boats on the market. If your valve looks like this:
Then, a quick search found this info on the boat fill valve:
Short Boat Valve
Here's a technical Line drawing
True Blue . . .
sold the Nauticat
Old 08-22-2007
SENIOR MEMBER
Thanks, but it is like Saling Dog described and I will take it apart this morning and repair.
Replacing SeaCock Gate Valve with Marine Ball Valve saurav16 Gear & Maintenance 30 06-15-2007 10:52 PM
Thru hull stuck Jotun Gear & Maintenance 25 03-11-2007 08:20 PM
Leaking Seacocks and Sink Drains Tom Wood Buying a Boat Articles 0 09-11-2002 08:00 PM
Leaking Seacocks and Sink Drains Tom Wood Gear and Maintenance Articles 0 09-11-2002 08:00 PM
Plastic Through-Hull Valves and Valve Flanges John Kretschmer Gear and Maintenance Articles 0 05-27-2001 08:00 PM
