08-22-2007
Merlin-
I think the OP really needs to RTFM... The high setting on a handheld VHF usually refers to broadcast power—5 watts vs 3 watts or 1 watt, which are medium and low respectively. It has nothing at all to do with the unit's ability to receive VHF transmissions. The squelch, which is "digital" is probably represented by a number on the display. I prefer the Standard Horizon units, which have a real squelch knob...
BTW, the broadcast power isn't always user-selectable on all units. Some frequencies, like 13, which is the bridge-to-bridge frequency are designated for short-range, local communications, and many handhelds will only transmit on these frequencies at 1 Watt.
Originally Posted by merlin2375
If you want to hear weaker and/or more distant transmissions you should turn your Squelch down, not up. Generally you should set the squelch to the lowest possible setting where you don't just hear white noise/static.
