08-22-2007
If you're going to be re-bedding the two pieces, it is likely that the other pieces are of the same age and going to leak soon...so re-bedding them at the same time may save you some headaches in the future. It would also be worth checking to see if any of the deck hardware goes through cored sections of the deck, and if it does, it would be worthwhile to pot the holes properly with thickened epoxy.
