Old 08-22-2007
Zogumwesterly's Avatar
Zogumwesterly is on a distinguished road
Purple power is good stuff!
I have been working on replacing the floor timbers in my boat and had to pull up the sole. when I pulled all of it up I realized what a derelict I had been because the whole bilge was coated in greasy, oily nastiness. A marina neighbor of mine suggested I use this stuff called purple power to degrease the bilge, Well I mixed the stuff to approximately the correct water to PP ratio(in the bilge) and let it sit for about 5 days. When I pumped this stuff out into a 55 gallon drum) the bilge was spotless(well a little bit of wiping was necessary.
Purple power is great, I just wanted to share this discovery with the few of you who haven't heard of it.
Old 08-22-2007
The stuff he's talking about is this stuff... LINK.
Old 08-22-2007
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Yep, it's excellent stuff, used it on the race bikes after every race ( being careful of rubber seals ), works great for cleaning the garage floor too
also, there's a product called oil eater that is also excellent and it's bio-degradable
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 08-22-2007
rewell6 is on a distinguished road
Make sure to wear gloves, it will remove all the oil from your skin and give you a chemical burn. I used some stuff a long time ago called "Blue Monkey" or that's what I was told. The chemical burn basically killed the outer layer of skin on my hands. Looked like I had a black glove on for a week or so. Didn't hurt, just looked bad.
Old 08-23-2007
scurvy's Avatar
scurvy is on a distinguished road
Send a message via AIM to scurvy
Will this stuff work with fuel spills (diesel) in the bilge as well?
Old 08-23-2007
Freesail99's Avatar
Freesail99 will become famous soon enough
My question is, will it work in cleaning a diesel fuel tank ?
Going sailing ....
S/V Scheherazade
Old 08-23-2007
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
Don't use it in a tank or a crankcase unless you can get all of it out as any remnant will continue to break down the fuel or oil long after you finish cleaning.
Old 08-23-2007
sailmed is on a distinguished road
source for purple power
Checked the link listed and found it was not available.
I found it elsewhere though I do not have ability to post a link.
Check "clean-rite.com"
Good luck to all.
s/v LOON
Catalina 34 Mk II
Rock Hall
Low-cost outfitting GoodOldBoat Gear and Maintenance Articles 4 11-09-2011 12:05 AM
What would you buy for $100,000? swo104 Boat Review and Purchase Forum 116 09-04-2011 08:05 PM
First time sail boat buyer martinojon Boat Review and Purchase Forum 18 06-15-2008 09:22 PM
Cruising beginner Seanmc Cruising & Liveaboard Forum 3 01-22-2002 04:39 PM
Good Lanes and Bad Lanes Brad Read Racing Articles 0 04-25-2001 08:00 PM
