08-23-2007
Cleaning the Bilge, but what about the discharge regs?
So my boat has the leaky 4-108 engine and a transmission that dumped most of its fluid into the bilge just before I had it rebuilt. Needless to say the soup brewing back there isn't the best. As tempted as I am to give it a good flush with bilge cleaner, soap, and fresh water I can't bring myself to hit the bilge pump switch. There is no place for all the oil to go but overboard and I can already see the sheen on the waters surface if I just let it go.
So what’s the best way to address this? I already have a drip pan under the engine so little oil is being added to the bilge, but there is almost always a some. Is this one of those things most people look the other way on or is there a simple solution? I suppose the only alternative is to either pump the fluids into a disposal container or find some rags that will soak up the oil and then discharge the water.
Any suggestions?
s/v Jargo
Singlehanding to Panama and beyond
