08-24-2007
Last Grumpy Old Sailor
Securing Shroud Turn-Buckles
Wondering what y'all use for securing the turn-buckles on your shrouds? The PO of our boat used small stuff (line), with reef knots. This is a PITA to get through the little holes in the adjustment screws and, if you don't... well, it simply doesn't accomplish anything. The little split rings I often see used work well, but you really should tape them. Not a very re-usable system. One boat I was on used tie-wraps. Works well, but again: Not re-cycle-able. And tie-wraps require diagonal cutters or a knife to get 'em off.
There was a "ring" I had once, maybe still do, somewhere, that consisted of two halves, hinged together, that snapped together opposite the hinge with kind of barbed ends. It actually locked-up pretty securely. ISTM something like that would be perfect. Tether it to the shroud with a length of small stuff so when it's off it doesn't wander away, and you'd be all set.
Jim
s/v Abracadabra
1976 Pearson P30
